SAU group by. haha. Bayswater is unchartered territory for me.. dunno if i would come out alive. joke.
sorry should have been alittle more specific. im North East subs. Templestowe, Eltham, Doncaster ect..
guessing around the $100 price bracket.
anyone recommend around there??
cheers
https://www.sau.com.au/forums/topic/190430-ac-regas-time/#findComment-3432175
cheers
let me know where you go as im in 'the areas' as well.
https://www.sau.com.au/forums/topic/190430-ac-regas-time/#findComment-3432182
Well worth getting a leak test on your system, otherwise the refrigerant will leak out again. Large leaks can cause a loss of charge in no time at all! some smaller leaks could be as little as a fue ounces per year. Most leaks occur on the high side of the system including condenser coil and o ring fittings. Compressor discharge and suction hoses are also another major leak point. Laws on control of ozone depleting Refrigerant gas including HCFC R134a prohibit a leaking system to simply be recharged hence it is against the law to re gas refrigeration systems including car A/C without leak repairs.
https://www.sau.com.au/forums/topic/190430-ac-regas-time/#findComment-3432209
yeah I got my a/c fixed at Protek a year or 2 ago.. still needs to be fixed.
Thank god my head gasket went just before last Summer so I was driving another car during the 30deg+ heat.
Graham at Albert St Automotive in Preston is really honest and does cheap general mechanical work (wheel bearings, servicing, RWs etc) but I think they get contractors to do their electrical stuff.. still cheap though.
Regent Electrical... or something like that.. it's on High St in Preston on the hill.. they do a/c repairs (alot) and didn't charge me to test my a/c and offer some solutions, they seem pretty honest.. (though I haven't had any work done there)
https://www.sau.com.au/forums/topic/190430-ac-regas-time/#findComment-3432261
cool. thanks for your help Kaz.
Preston aint too far at all. ill sus it our over the weekend.
might have to bring out the ol' phone book and do a ring around too.
https://www.sau.com.au/forums/topic/190430-ac-regas-time/#findComment-3432314
the place kaz was talking about is regal auto electrics: 793 high st reservoir 94703811
they do regas there but from past experiences of getting elec type stuff done, they were pretty pricey.
https://www.sau.com.au/forums/topic/190430-ac-regas-time/#findComment-3432523
where abouts are u located? there is a a/c workshop opposite racepace in bayswater i think - i got my a/c regassed there
would they go to racepace to do it or i have to drop the car at their workshop???
dont wanna to leave my car at any workshop other than racepace....
https://www.sau.com.au/forums/topic/190430-ac-regas-time/#findComment-3433488
you leave it there...to regas it took something like an hour and a half....i went for a walk, got something to eat, and came back, and it was done :)
edit: the place is called KSR Air conditioning - 9762 1011 (the guy's name is Keith)
https://www.sau.com.au/forums/topic/190430-ac-regas-time/#findComment-3434737
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
