Hey Guys
In the stages or tearing my engine down, ready for a rebuild.
There are a few retailes of RB30 Rods at the moment
- SPOOL
- ARGO
- Rod Factory
But whats got me confused is
Centre to Centre: some have 152.5mm and some have 155.5mm
Will either of the 2 work?
Anyone else come across this and what have you done
JD
https://www.sau.com.au/forums/topic/190554-rb30-rods-height-make-a-difference/
Brad I spoke to you this morning about that, thanks for your help
Rods Factory, i know they are on ebay are 155.5mm
RacingPartsfactory.com also have them as 155.5mm
Will using the 155.5mm Rods pose a problem? I know they are 3mm longer, i am planning on using CP 8.2 Flat top Pistons with them
Edited by D1AUS
Umm yes - the pistom will protrude 3mm out of the bore and you wont be able to bolt the head on.
It just wont work - you will need to get a custom piston made to suit.
But from my calculations, it is ok.
RB30 Specs
RB30 Deck Height - 9.075" (230.5mm)
Stroke - 85mm
Crank Throw - 42.5mm
Compression Height - 1.280" (32.5mm)
Using Spool/Argo Rods - 152.5 C/C
Deck Clearance = 230.5 - 42.5 - 152.5 - 32.5 = 3mm
Using RacingPartsFactory/Rod Factory Rods - 155.5 C/C
Deck Clearance = 230.5 - 42.5 - 155.5 - 32.5 = 0mm
Is that right by your calculations, therefore using either Rod, should not matter.
However, if you see an issue of deck clearance, you can always use RB25/26 pistons instead, as they have the same bore, but a smalled Compression Height
Edited by D1AUS
So that calculation above is wrong then??????????????????????
RB30 Compression Height - 1.280" (32.5mm)
RB26 Compression Height - 1.193" (30.3mm)
RB25 Compresson Height - 1.240" (31.5mm)
Using 152.5mm will yield 3mm Deck Clearance via that calculation
Using 155.5mm will yield 0mm Deck Clearnace via that calculation
Now thats even more confusing
Why not just use the Argo or Spool rods and be done with it? They both work without any issues?
Its not just a matter of simply using any rod. I'm trying to maximise the compression ratio etc with my setup. And with the calculations above and speaking to Distributor for CP in QLD.
Standard Rods have a 3mm deck height according to this calculation. As the CP RB30 Pistons are Dished not domed. Thats my arguement here.
Just trying to find out from others who have done this etc.
I understand Spool Rods are of good quality, but just seeing the available options to maximise the setup, thats all.
JD
Im building a 30/26 now with 9:1 comp using argo rods 152.4mm center to center
also using je custom piston compression ,height of 1.283,
0 deck height
havnt got the pistons yet but thats what i did to get the comp i want
0 deck height
Thanks for the feedback mate, I assume they are a domed piston????????
Im not trying to sell you my rods - just trying to explain that you are going to get in all sorts of shit of you use those ones with the 155.5 c/c
CP 8.2:1 are a flat top that come flush with the deck.
CP 9:0.1 are a domed piston. The flat of the piston come flush to the deck with a small dome in the centre.
CP RB30ET pistons have a small dish with valve reliefs.
To get 8.5:1 your prob best to use the 8.2:1 and skim the head - but obviously work backwards and cc everything first to calculate how much to take off the head.
Brad
By all means i do appreciate all your help, thanks very much
I'm just going by all the figures at the moment. Obviously, I will dummy everything up check chamber cc etc.
Just by the specs, thats what i get from the calculation. I know standard rod is 152.5mm
From your experience, what is the standard deck clearance for RB30? standard parts
deck height is 0 rod length should be 6"{152.5m} dont use any other rod length
and yes my piston will be dome
if u use the cp piston u can buy the right one off the shelf for 8.5:1 comp
u will only achive this if ur block height is standard and combustion chamber cc's are close to standard{65cc"s from memory}
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
