make a japanese account if you need more help PM me and I will send you all the info you need. Once you have downloaded the demo it will available on all your accounts on your PS3. Remember the demo is only available till early november if i remember correctly.
Ok you guys had me working hard on this. My worse corners are the Hairpin and shacane (mind the spelling its late). I have got those corners a little better now and I had times around low to mid 4'30 put didn't want to post till I was number one again :) . I mastered the first corner in 4th and second corner in 3rd which shaved off the extra time I needed plus getting my worse corners better. This is still with the sixaxis as the table for my G25 is currently getting built.
Ready to rise to the challange?
Car:GTR 07
Front Tyres: R3
Rear Tyres: R3
Complete Time: 4'29.595
nice! well I'm officialy rubbish. I get 3/4s through an awesome lap only to throw it away somewhere. :)
my best laps are stil a 18 first lap and a 12 second lap but I can never get the two together. I've gone backwards in fact I tend to be in the 34-36 zone now with an off or two somewhere. ;)
Josh your lap doesn't count because I knew you would do that, Having a better lap time ready for when I finally beat yours. I spent about 4 days trying to break 4'30 mark and that lap that I did it on was luck I think. Now you expect me to even better it again.
I should disqualify you for have a 180sx in your name and nothing to do with skylines :)
Back to track over the weekend for me, I pick up my puppy tomorrow so hopefully he wont try to steer the car for me.
lol at least now you have incentive to keep playing and get better! I have the type x because when i made my account i had a 180, but since then i've had an R33 and R32 (in the space of just over a year lol).
I still suck. had about 10 attempts and can't put it all together. I was on an awesome lap just up to the turn before the back straight, had already passed all car (usually I get the last 1 or 2 on the back straight) and my gf walked in front of the tv, and I ran wide. dammit.
so I gave up and played warhawk instead. and yes I'm pretty ordinary at that too. haha.
Downloading it now :P
if anyone needs help creating a JPN account try this link
http://blogs.ign.com/xheavenxsentx/2006/12/09/39684/
Edit: i see 4:29 is the time to beat, if u dont see me back in this thread i couldnt do it :dry:
2nd edit: ran 439 on my first go, damn i have some work to do
Edited by 2630GTS
  • 1 month later...
did a 4:27. not sure if that's good, but it was my best, and I had an off at the hairpin. did a 2:17 first lap (good lap) and a 2:10 second lap (could have been a bit better).
and I only just picked it up again today and it was my second go. :banana:
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
