Went in for a tune of my RB26 the other day and had lots of problems...
Most are a easy fix but one niggling on is the fact that my d-jetro map sensors are bottom lining at 20psi and I'm told that they generally max out at 26psi...
Any ideas why this is happening?!?
Cheers
Simon
https://www.sau.com.au/forums/topic/190702-power-fc-d-jetro-problem/
where is the pressure source taken from? i have had issue's when not taking the source from the actual throttle bodys (bit of a pain but worth the effort)... hooking up to the balance bar tends to cause a few issues.
where is the pressure source taken from? i have had issue's when not taking the source from the actual throttle bodys... hooking up to the balance bar tends to cause a few issues.
the intake manifold just before the throttle bodys?!?
Edited by Cerbera
before head and butterflies or between plenum and butterflies? it should be between head and throttle plates as shown in install manual.
ah yeah so thats the scale then and correction
that doesnt mean your maxing the map sensors
have you got a data log of the run?
check out what voltage PIM1/PIM2 get to, if they hit 5v they are maxing
sorry to hijack ur thread cerbera but i thought since ur on the topic of D jetro's i got a quick simple question.
they only made these for the GTR right? aint none of these got GTST or GTTs?
You can modify the ECU loom for the R33 GTST to be able to use the D-Jetro. I Don't know if this is the same for the R34 GTT (probably depends on the ECU plug shape as much as anything).
yeah RB26 D-Jetro can be used in R32, R33 and Z32 (300zx) but R34 GTT has a totally diff ecu plug.
did you see my last post?
is PIM1/PIM2 actaully maxing at 5v?
took stupid thing for a drive last night and boosted in 3rd gear to 23psi and the PIM voltage read 4.867V
this was only just on boost as the car is only rwd at the moment and likes to smoke 265's when it comes on boost and female passengers tend to get scared!!!
is this classified as close enough to 5V?!? maxing out?!?
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
