  • Replies 45
Well my tyres got a great endorsment from a driving instructor at the skid pan last weekend. I have 275x30x19 hankook silica tyres at the back and even the instructor was having a VERY hard time keeping the car sideways on an oiled and wet track. He was very impressed with the grip, and i was impressed with his comment :).
https://www.sau.com.au/forums/topic/19076-tyres/page/3/#findComment-419101
Originally posted by nismoR34
CR34TION: I think we need to swap cars to find out whats going on! I can also have a look under the hood for you, I know what to look for :)
If you ever come to an event we can do this :)
You will be on my turf on Thursday nite:P
Maybe we could get together.. though i have my dad's b'day dinner to go to. I might also be taking a sicky on Friday, but would be good to compare cars. Let me know.
Sorry Daz for jacking thread.
I had Bridgestone Potenza's on my Type-R and they did a great job, comes standard also on the s15 and wrx.
Cheers.
https://www.sau.com.au/forums/topic/19076-tyres/page/3/#findComment-419105
I highly recommend eithe the Falcan Azinis ST115 or the Bridgestone RE540 semicomps for grip. FM901s are also an awesome tyre.
I currently have the ST115s on my GTR and they hold really well. Also, they helped take my car to a 11.58@124MPH at Calder Park with a slipping clutch so the grip isn't a problem.
Nittos are excellent tyres for what they are designed for. Ie. A streetable drag tyre. Although not legal in AU, a cop wouldn't be able to tell as it has a good tread on it. The only thing which differentiates them from legal street tyres are the softer sidewall (excellent for dragging) and very soft tread (softer than semicomps). They are good for about 12,000 kms on the road and about 5,000 strip kms. Don't bother with them on the circuit though, the lateral rigidity is way too soft.
As for the wet, Nittos' won't go anywhere and you will do nothing but kill yourself as the tread is simply designed for dry, straight conditions.
https://www.sau.com.au/forums/topic/19076-tyres/page/3/#findComment-419809
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
