Dave (Silva33) talks about this car ALOT, and keeps saying how awesome the package is.
It's the perfect 32 gtst combination: powered by rb25det goodness :P
Good Luck with the sale :P
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
