yes if your crank pulley (aka harmonic balancer) is 'out of balance' and noisy then my advice is very simple. start saving. :P
check your balance bolt is done up tight, as it comes loose it will make a noise which sounds like a bearing is stuffed in the PS pump or something. it wont take long for the balancer to wreck the keyway it's located on, and if you are really unluckly things only get worse from there.
BB surely his mechanic friend would pick up a loose h/balancer, he should be able to see that himself!!
thanks guys, it sounds about right what your explaining, its only been happeneing for a week or so, and i've maybe done an hours driving at most. got to get to kirawee tomorrow morning and it should be safe.. i hope!
i'll make note of him to check that out, amoung other things.
thanks again.
My key that fits the harmonic balancer just decided to break a few months ago.
Result was new harmonic balancer and key...the sound was like a rattle in the front end of the motor.
The balancer was still working..(on that is..lol)....not working well though.
3 weeks after thatI heard some other rattles..this was getting worse every day.Turned out the drive shaft bolt(main)..was just about to fall off....the thing was wobbling like a drunk..lol
Result..no damage...2 bolts now..one on top of each other..problem fixed.
4 weeks after my exhaust bolts decided to drop off...ffs....rattled a little before it dropped..lol.
I had not noticed one had dropped off and though nothing of it..until both went.
Result..two new bolts with 2 others for support on top.
A friend of mine suggested I should get a tyre gun and tighten everything up.....with the force put on the car
at even half throttle just shakes,breaks or losens up all the bolts.
Anyway...could be lots of things..good luck finding out.
Edited for bad spelling
Well it made it to the workshop this morning. and i gave him a short list of things to sort out. fingers crossed all will be ok.
if not i'm going to need someone to write me a nice email in japanese to a company over there to get myself a new 34Nur long motor. seems like its the cheepest option out of the lot.
this sounds rather similar to what i had going on.
Edited by Angus Smart
oh, and andrew stock pistons do have AA stamped on the top. I've seen AA4 too.
I will try get a look if i get it back before i go away, The auction report says that there is n1 but wether thats true or not.
might get myself one of them boroscope things to have a peek inside.
theres auction report link from years ago. And your comment, i.e. Circuit thrashed sllluuut i think it translates to.
http://www.skylinesaustralia.com/forums/t83683.html
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
