a 1993 R32 GTST 179000 on the dial Suspension was installed at 170000, engine was installed a 171000 as was the clutch, and the turbo has covered less than 2000 km
R33 RB25DET
20 thou oversize forged pistons
forged h beam rods
reconditioned (new springs valves ect) and lightly ported head
N1 oil and water pumps
ACL race bearings
Cometic metal head gasket
ARP head studs and rod bolts
R33 Gearbox
R33 Differential
Garrett GT3076R Turbo
Tomei Poncams
600cc injectors
Z32AFM
HKS Hyper 3.5" exhaust with custom front pipe
Splitfire Coil Packs
OSgiken TS2BD twin plate clutch rebuilt by NPC
C’s Short Shifter
GFB Stealth FX Blow off valve
Bosch 700hp rated fuel pump
Apexi Pod Filter
Apexi PowerFC
Greddy Profec B spec 2 Boost controller
Custom FMIC
Custom intake piping
Oil cooler and filter relocation kit
Suspension and Braking
HKS Hypermax 2 coil over suspension
Front and rear strut bars
B pillar Brace
After market sway bars
JIC adjustable castor rods
JIC adjustable upper arms
Whiteline Pineapples
R33 GTR Brembos with DBA 5000 rotors
Front: 17 X 8 wheels with 235/40 semislicks
Rear: 17 X 9 wheels with 255/40 semislicks
Exterior and interior
Full respray- Custom Blue
Genuine GTR Bonnet and Grill, Front bar, and rear spoiler
GTST Type M side skirts
GTST Type M rear pods
Genuine R32 GTR Front and Rear seats
Genuine R32 GTR Door trims
Genuine R32 GTR Headlights
Nismo Gearknob
Audio
DVD player with 4 inch screen
6.5" Jensons in the back and JL 6" Splits @ the front
Last tune was a very safe 260rwkw it was making 300rwkw previously but it was not safe, a safe 300rwkw is only a thicker head gasket away! At 260rwkw this thing still really hauls and handles beautifly too as it has that little bit of extra attention paid to the suspension
I am asking 24,000 neg. this price is mostly designed to ward off dreamers and tyre kickers, if you are interested we will talk! I have included a picture of the car with 18inch starcorp impuls, if the buyer perfers these wheels could go on the car instead as I still have them at home.
PM me to discuss the car. Hope to hear from you soon!
Andy
OFFERS AROUND 20K WILL GET YOU THIS CAR TODAY!!
https://www.sau.com.au/forums/topic/191365-1993-r32-gtst-with-rb25/
Thanks for the kind comments guys! It will be sad to see her go after all the blood sweat and tears but after the best part of 2 years i am ready for a change!
my kind of no bullshit car!
ive never seen it... shooooooooooow me.
you could but it and see it all the time :ninja: ha ha I will even give you a special members price :)
someone buy this car.....this is an awesomely kept and run car has everything you need and nothing to put in except fuel...
I have been in this car and its a wet dream on wheels.
  • 1 month later...
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
