hey, during the past week, my friends r33 developed a leak somewhere from the front on the left side, it was leaking some thick, translucent greasy stuff and i think its a dead bush, but i dont know what the part its leaking from is called, here's a pic, do any of u guys have an idea of what it is and how to fix it, can the dead bush, if that is the case, be replaced with pineapples
https://www.sau.com.au/forums/topic/191385-bush-leak/
yes that is def your castor buses, pretty hard to do your self so best to take it to a work shop to do it,
mine were like that but i then decided to get them replaced with a polyurethane bush kit that superpro make, for a few $ more i went for adjustable castor bushes, which gives you adjustable castor, to help tune in more wheel alignment specs to help the car drive straight,
when your stock bush completely drains out, you might notice that the car will pull to one side, but its not something that will cause immediate dramas
workshops shouldnt charge a hell of a lot in terms of hours, its only a few bolts, then they have to press the old bush out and put the new one in (extremly hard to do your self) then it will need a wheel alignment
the part numbers for an r33 for the superpro bush kit
-1202k - direct standard spec replacment
-1202AK - adjustable caster(worth it )
https://www.sau.com.au/forums/topic/191385-bush-leak/#findComment-3444789
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
