dont have myspace.
now i can appreciate that you are in your "ladies time" mate
but enough is enough. you arent worth a single drop of a peadaphiles crotch sweat.
my bad for the whoring.
Edited by r33cruiser
dont have myspace.
You don't know when to admit defeat do you. That's OK though....you are providing everyone with a good laugh.
You have been undeniably exposed as a wanker and a bullshit artist, but you continue with your pissweak attempt to save face.
You obviously have no shame, or no brain.....probably both.
Carry on......I'm loving it :)
All the off topic chat STOPS NOW!!!
r33cruiser, mitchy and lazy-bastard consider this a friendly warning to stop with the b!tching contest with each other or the next time it will be an official warning and a holiday...
The forum is here to aid ANYONE AND EVERYONE not to see who has the biggest e-penis :D
If you have a problem with another user or what they are posting then dont be like all the other terry tough nuts and bash that keyboard, send them a PM or a mod or if you think the post shouldn't stay REPORT IT.
Back on topic before i have to organise a group buy on Maxi pads for everyone :)
Cheers GMB
Can somebody give me a picture or link to those fancy fitting you have been talking about?
I need to mount three thermo couples, one in the airbox, one in the turbo hot pipe and and in the throttle body.
thanks chris these alloy nuts have to be available here, any idea who sells them (se qld)
cheers leigh
I bought a couple of the 1/8" weld on Aluminium Nipples from Motorsport Connections.
Cost me $25 delivered and I got a free hat!
shit i got to slow down and smell the roses,looked at m'sport connect and thought they were USA, what a great business, thanks BS,
i wonder if i'll get a cap
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
