im expecting about 200 rwkw on the stock turbo with supporting mods.
I'm aiming for the same. You went an SAFC II?
emanage ultimate
It's a little more pricey yeah? Removing speed limiter is a must, i don't want approx. 200rwkw and then limit it to 180km/h, then there's no point making extra power :P
i went pfc but safc will be fine but no speed cut maybe get a safc2 and a speed cut defencer to save on cost from what ive read emanage ultimate is a very good piggyback if you find the right tuner to install they are like 800 + 500 for tune which is far less than the 1500 + 500 for a pfc
Edited by SevenAngryPenguins
I Sold my SAFCII to my brother for $200, Unique is goin to fit it For $150 & Tune for another $150, $500 all up.
If your going to do major mods later I would go for SAFC option
I Had FMIC, Boost control and SAFC had approx 200Kw atw pulled 13.3 1/4 mile on 19"s
i agree safc+rsm cheap and effective
Good point fellas. So it'll work out cheaper to get SAFC II & the RSM together + tune rather than something expensive like an EMU or Power FC...
I'm gonna head down that path by the look of it.
Ahhh can i still achieve 200rwkw without the SAFC? I'll end up with one anyway because the factory fuel maps don't milk maximum power i know.
Just get an ecu. You already said you're gonna upgrade th car in the future.
its not the cheapest option for sure, but its the best.
we don't drive skylines to save cash now do we...
i have done it mate. from memory it is wire 32, dont quote me on it though.
nothing bad has happened to my car, it is better than ever.
besides u only cut the speed/HICAS diagnostic wire.
besides u should remove hicas anyways....get a lock bar
UPDATE: I took the 33 for a run last night to see when the speed limiter cut in. I hit 180km and nothing happened. The speed gauge continued to increase into 'nothing' reading, i'd say it hit 190km before i backed off.
What's the story here? Doesn't the limiter exist? Or does the dail only SAY it does 180km?
ALSO installed an R34 side mount intercooler...made a BIG difference so i think i'll hold off on the front mount for now, and save for an SAFCII + tune.
Cheers :angry:
It does exist. But the combination of the speedo being out at high speeds, and the fact that your rims are probably a different radius from stock result in your indicated top speed going over 180kph when you hit the limiter.
Good point, they're 17's on now. But i thought AT 180km the ECU would kick in, regardless of the rotational speed of the wheels.
Is there a way to find out if my ECU is modified? I removed the kick panel and had a looksie but i'm unsure of what's what.
Cutting wire 53 removes the speed limit and no it doesn't get rid of your Hicas, whoever told you that is an idiot, its the speed signal wire and the Hicas diagnostic wire. From your gearbox you have a speed signal wire into your dash, then from your dash to the Hicas computer in the boot and to the ECU in the kickpanel. With it cut your car will do about 230-240 with basic mods.
The reason people say that you get rid of the 180 speed limit with aftermarket computers is because aftermarket computers don't have this feature built into them.
Another reason why people say that the SAFC or RSM removes the speed limiter is because they use the speed signal wire......which most people cut and wire to the SAFC or RSM, see the pattern here? It's all to do with that one wire.
Cutting wire 53 removes the speed limit and no it doesn't get rid of your Hicas, whoever told you that is an idiot, its the speed signal wire and the Hicas diagnostic wire......which most people cut and wire to the SAFC or RSM, see the pattern here? It's all to do with that one wire.
Aahhhh makes sense now hehe. Thanks mate, i'll take another look at the ECU. If i feel confident i've found NO. 53 i'll give her the chop :wave:
Looking forward to freedom lol
speed cut comes in at 5,000rpm in 5th gear which in my car is 190km/h... which I hit about 3/4s down most straights ON THE TRACK
I can't for the life of me think why you would go bother chopping wires other than then you can brag to your mates about how quickly you were going when you got done for speeding......... and how for the next 6 months you will be needing a lift;)
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
