  • Replies 367
Posted Images
i bet ur the wanker that did it. guys like u need to grow some balls
lol, sorry buddy, as i said, if it was me, it would have been bigger! much bigger! as for the grow balls comment, thats not nice... shut your mouth before i put my foot in it!!!
mate who do u think u are u have made a handful of posts and u come on here thinking burnouts are cool. ppl like u give the import seen a bad name. grow up u tool
White 33 GTR, actually. And no i dont give the import seen a bad name, people like you drivin around in nugget gtst are the problem thinking your mad hectic... soft
mate bring ur shit box boat anyway anytime and ur on. then we will see who has a nugget
Hmmm, i dont know what everybodys on about... i thought that burnout was pretty good!!! 10 points for tryin anyway
Its not the burnout, it was the place and time. I thought it was kinda stupid seeing as I saw the same patty wagon and Commodore wagon cop cars pass the place like 6 or so times sinse we got there. Not to mention the general public seeing a Skyline doing said burnout and associates that with every import under the sun.
I do admit, it was pretty good, but again, wrong place, wrong time.
Sorry Wing Wong - but for someone who is always at WSID keeping it off the streets, burnsie is far from what you describe.
:P
cheers,
Chris
Edit - Echo Matt - cassbo's comments. Wrong time, wrong place. Simple as that. Thats the type of tool we need off the roads.
mate, im ready and waiting! bring you and your blouse car round for an old fashion beat down!!!
mate im serious u beta be able to back that mouth of urs cos i will flaten u. pm me where and when and its on like donkey kong bitch
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
