Item: 18" ADVANTEK TITANIUM ALLOY rims
Age: unknown
Condition: not to bad a few gutter scrapes but price makes up for it
Price: were $699 ONO NOW SOLD
To Fit: (What car) multi stud 5x114.3 and 5x120 (i would asume), fit my r33 jus fine
Contact: PM me
Comments: rims have a couple of gutter scrapes, but have excellent tyres, and are very uniquie, havent yet seen another set in gold, look mint on red car. and at this price u cant go wrong piss your stockies off 4 $300 and 4 $400 out of ur pocket ur cruising on gold 18z wid top tyres....
rims also clear R33 jus fine, no scrubing or anything, and the nut cover has an inbuild lock nut, which is included aswell as the key...
BUY NOW AND RECIEVE
4 x rims (2 wid Regal [temp A traction A] 2 wid Lenso tyres) with 95% tyres
4 x centre caps with lock nut key 2 stop ppl taxin your rims
20 x chrome wheel nuts.
2 x spacer plates - if required (dont need on R33 gtst, but maybe on other cars??)
1 x hug - what can i say, im a nice guy.
Edited by skiwhine
PRICE DROPPED and tyres are Lenso x2 and Regal x2 (temp A traction A) all tyres like 95% cant really see rim damage on pics u have 2 see in person... im down to $750 ONO practically giving these babies away now also come with 20 x nuts!
the damage is not light, thats why the wheels are so cheap, i was quite happy driving with them on only changing wheels cos i found the rims i wanted at bargain price, these rims would suit person sick of driving on ugly stocky's who is saving for the rims they want or waiting for them to pop up cheap, these are halfway house wheels! lol
Edited by skiwhine
and im pretty sure the offset is +40, but as u can see in the photos they sit just fine on a R33 dont scrub or anything stupid like that and they are mighty close to the front brakes, like merc close :P
BUY NOW AND RECIEVE
1 x hug? wow, that's a deal and a half! good luck with the sale
free bump
PRICE DROP TO $700 ONO come on some1 must want 2 piss off there homo stockies and slap some decent rims on.....
think about it once u sell ur stockies (for say $300? if they have tyres) ul only be paying $400 out of ur pocket for these rims... u would pay that jus for the tyres! u cant go wrong!!!
Edited by skiwhine
chrome is peeling in places on all rims and some of the spokes have scratches, to fix u need $5 worth of sandpaper $14 worth of beer, $4 worth of spray paint and $4 worth of clear coat to make em minters, but u can drive on em they aint hideously stuffed i was quite happy 2 keep em but i found rims i really liked, cheap (was still alot more then wot i am selling these for) so i bought em, if i had another 5stud car id b quiet happy 2 keep them lol
the last image is the pic of damage to the rim, as i stated to most people that asked, you cant really see the damage in photos, or at all actually, this rims is typical to all the others bar 1 which has a little more chrome missing, also please note that any 'bubbles' that apear are not defects, just water droplets because i gave them a quick rinse with the hose, thanks.
my bad wheels aint advanti but are actually
ADVANTEK TITANIUM ALLOY WHEELS - they felt light when i picked them up, now i know why!
Edited by skiwhine
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
