Newcastle Mg Club 50th Anniversary King Edward Park Hill Climb
I entered the Newcastle MG Club 50th Anniversary King Edward Park Hill Climb on the 20th October and had a ball, i was able to put a camera in my car with the help of Dumhead and tape my 4 runs on the Saturday and put them up onto youtube.
A big thanks must go out to Shane, Nicky and Michele for helping with the car and packing up on the Saturday afternoon i had a ball and will try and make it again next year and improve on my 42.9 second best run.
I have posted this up on a few forums to try and drum up a little interest in the event as it surely is a magnificent area to run such and hill climb and can highly recommend it to all.
Please enjoy the footage and feel free to leave your comments on youtube if you like the footage.
Matt
Run 1
http://au.youtube.com/watch?v=05U9RV6zqsM
Run 2
http://au.youtube.com/watch?v=LIZxxQ-V0WI
Run 3
http://au.youtube.com/watch?v=rbqkVE_7Jp0
Run 4
http://au.youtube.com/watch?v=1DQqjpEfRyY
Edited by boxheadmr
well done looks like you were having fun. plenty of wheel spin and rev limiter :) love you you went thru the hairpin and chicane on the last run in particular
they take their chicanes very seriously, don't they :ninja: no idea why they put them on the exit of a hairpin corner though?
oztayyan car eh?
and I love the "your speed is sign" did you get time to read it?
it is a great little hillclimb, the narrow bit is called 'the pinch" for obvious reasons i think they use the hay bales after the pinch to slow the cars down becasue the right hander before the hairpin you can get a fair bit of speed up in a short distance and a torana actually spun out and hit the power pole on the day.
There was two speed signs, one just before the pinch - think best was 106klm/h and then i think i got as fast as 80klm/h on the second one but not sure as i was not looking just was told by friends there.
Duncan you should try and make it next year is a lot of fun and great spot to have it.
  • 4 months later...
  • 6 months later...
That course looks too tight IMO for a skyline to have fun at
It's largely ran by smaller cars although an R32 GTR with mild mods, good tires and brakes would handle it well enough. :bunny:
Guilt-Toy ran in it this year and had a good time from what I can gather.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
