i once was almost the only person around with a green 33 but alas no more....
oh well least mine was green when it rolled from the factory :D
looks good tho oor33sky_
HeHe thanx 4 the nice comments!!!
Nah mine is not really green so much (hard 2 tell from that shot)..it is actually a chamelion style colour - green 2 blue 2 purple
Hope 2 c u guys around :rant:
hi all, saw a skyline with green stripes on gympie rd sunday, thought it was a subaru at first becuase i saw a subaru sticker on the side of it then realised different, sorry for being rude if it was anyone here i was too tired to say hello (been working all day)....so ill say hello now..HELLO!!!
25det - were you in that gunmetal grey 33? I waved, but they just looked at me for a sec then continued staring ahead, so just assumed that they were wierded out by the stripes.
And what Subaru sticker on the side?!!?!? I have the New SAU sticker, Brake Distributers, Bob Jane T-Marts and Automotive Technique in a shopping list on the sides, not Subaru :)
yeh that was me and my gf, i thought i saw a subaru sticker probably not, thats how tired i was, anyway yeh stock gry 33 was me
Wide tyres are the suck, just replaced my 4, 2x235's were $160ea and 2x255's were $300ea.
And you'd be very surprised how much difference a pod and zaust make, when mine was bone stock, yes totally stock, I ran a 137rwkw then put a cat back super dragger on and ran 152rwkw on the same dyno no less than 4 weeks in between runs.
Now I got 177rwkw, hmmmmmmmmmmm mid range ROCKS with an SAFC tuned properly :D
Now I got 177rwkw, hmmmmmmmmmmm mid range ROCKS with an SAFC tuned properly :P
Try replacing 265's!!!! ouch!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
