sorry nismogal didnt know it was you guys.. that was miranda in the black r32 shes new on here... it was great to see 57und mspsi 92sky :(
you guys seemed to be having your own thing didnt want to barge in ...
Woohoo! Someone finally spotted me :D
I waved, but i didn't see if you waved back or not B)
Your car looks nice and clean, by the way :D
white 32 leaving autobarn springwood late this afternoon. 33 rims. i think it was sir32? not 100% sure, didn't catch the number plate.
Woohoo! Someone finally spotted me :O
Your car looks nice and clean, by the way :)
Yep i saw you wave, but our windows were up. We waved from inside, but tinted windows...
The car is pretty clean, but not enough for the cops (got defected 2 nights ago)
Don't know if you remember us, but we met you on the byron bay cruise (my brother-in-law has the 32 with rb25 conversion, which now has 33 rims on it thanks to you).
Noone ever sees us either :( .
Edited by darren32
Spotted a black R34 on the south-east freeway this morning at about 11am. Plate was NSR-034. Needs to make up his mind!! I passed him 4 times!! He was either doing 130 or 90??? Playing tag with a commodore maybe??
Dave
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
