Spotted 'HLUCN8' (I think thats how it was spelt) on Lacey Rd yesterday... sweet looking GTR :O
I was in the black R34 GTT sedan...
Ha Ha spotted...
i saw you too, didn't know if you were on SA or not.. now i know
Spotted 2x Maroon R33s. Both in Browns Plains. One parked with chrome zepatanis or whatever they are.
The other being a right fool. 120kmh going round on to Beauy road from the Logan motor way at 5:10pm is not bright. If you want to kill people use a gun, its safer.
Spotted Cya 33 at aspley tonight, also Aphid, and dou33 tonight at aspley...
was fun cruisin with ya, and good to see three skylines smoking them up, and showing off to those stupid commodore wankers..
by the way greg, car looks and sounds awesome... Finally good to see ya back on the road now the car has come back from somewhere thats capable of getting a result.
hahaha, gotta love it when the mods remove are rights of freedom of speech lol or in this case freedom to write.
its not about removing your freedom of speech, its about staying on topic, and not filling the thread full of back and forth arguing.
slap it out in whoretown for all I care.
The one with the chrome rims, is a chick. She works around there but its a nice car. Rims are for sale. Spotted a black with silver graphic up side at round-a-bout at Heathwood. Sweet ride
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
