how about the rear shot of the 33 in the flood photos of todays courier mail
i should get that and have a look, could well of been me, i almost got stuck out bulimba way yesterday. water f**king everywhere, trees too :S
saw a red\maroon r32 gtr at moobah last nite and a r32 gts-t? at alex any 1 on here cuz i thought i saw sau stickers
there was a r33 and r34 somewhere to but cant rembmer where
Edited by red_screamer
Spotted This 34 Sedan on the M1 usually see it everyday
nice Rego plates :thumbsup:
Are you still driving the audi into work, I thought you had a yellow R34. Makes it harder to spot you back, give a wave next time. :)
Are you still driving the audi into work, I thought you had a yellow R34. Makes it harder to spot you back, give a wave next time. :thumbsup:
Yeah audi is my work everyday car yellow 34s usually parked at home use it once a week only.. see you everyday will wave bk next time :)
I think that was me :D What were you in??
Was in my blue (green depends on who you ask) 33 with 400r bar
If it was you i saw you on the springfield side of the mwy headin towards springers and i was goin the other way
Edited by m0rt
Spotted Japtaxi (Will) at Market square on Fri night.. was a bit lonely tho.. :D i guess he will need the coffee meet back.. :P
haha vince i was just having dinner with a mate.. u looked a bit of "wtf" when i call out to you :teehee:
spotted MIZ34 silver 34 gtr parked on esher st holland park tonite :P
*hi alicia* :(
Edited by japtaxi
Yea I'm pretty sure that was me ;)
haha vince i was just having dinner with a mate.. u looked a bit of "wtf" when i call out to you ;)
*hi alicia* :)
That was definately me :D Visiting my new in laws hehe :cool:
Spotted yellow r34, FAT34, on compton road, calamvale, yesterday afternoon. looked like it had a bit of drift damage perhaps, to the rear quarter which has been repaired???
i was in my bluey... i only ever seem to spot other skylines when i'm driving the bluey.
hallo
i know its not the place to post it but i really need ur help guys.
i just bought a skyline (import) and it has a aftermaket steering wheel. none of the mechanics i know want to give me a wrc couse the original driver airbag has been took off. i dont want to put bloody airbag and take it off in next 20 minuttes.
if anybody know a place where i can do it ??
i will be more than happy to pay for it extra
please help
thanks in advance
hallo
please help
thanks in advance
Best u source the proper 34 airbag steering wheel and get it replaced. Replacing the airbag steering wheel with a non airbag one on the 34 is an instant defect.
i think thats my only chance..
any idea where i can buy it ??
thanks
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
