spotted Glen PNK32 on Edward Street opp the Victory last nite by the time i got towards you were gone.. was n foot , also spotted 911-GTR R32 on the M! a few moments ago was in the lancer
Spotted SPOILD R34 Coupe near gardencity today 11am
xxx-IOJ, white R33 GTS25t with what looks to be a boot lid from a GTR V-Spec (spoiler, badge and sticker), V-Spec front bar etc, a bit of other damage so suspect it's been fixed with parts from a wrecked GTR. Bad luck mate :\
Spotted white R34 with black tribals on the back...gave me thumbs up...I asked if he was in SAU....said 'nah' then I watched the show as a 911 porsche pulled up next to him...couldnt keep up though...(non-turbo 4 door 34) :whistling:
Oh....also spotted silver 4 door 34 with only front kit at 'WOW' underwood...2nd time i seen ya....
spotted a black 32, red 32, black 33 and white 34 cruising noosa parklands on the weekend. The black 32 sounded very angry blasting up 'the hill', actually they all sounded very nice. Good to see the north sunny coast boys enjoying their cars, keep it up.
R32 GT-R from Lydon Rd turning onto redland bay rd towards Vic Pt
Also at same intersection same time, R33 GTS-T with some sorta kit on it going towards capalaba, would have seen the 32 aswell.
R32 GT-R at about 9:20pm in cleveland
So many skylines around, i'm so lazy to post.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
