spotted an absolute tit in a white r32. may have been a gtr. no wing, numberplate was 222 *** or something like that. Nismo rims.
Lost control on ipswich rd, just before moorooka. mounted the island and started going the wrong way. then did a u turn, and then another u turn, and fishtailed up the road. absolute dipshit. fugly bastard too.....
Spotted alot of R33s over the weekend ...cant remeber plats but one of them was a weird looking black 33 with orange fibreglass bits.. OVL33 i think it was...
Spotted Devils_advocate (Adam) in mt gravatt
Spotted This R33 looks very familier to Danos car.. but maybe it his twin had SAU stickers on it ...
seen that black/orange r33 before. it's got a widebody kit on it, with orange highlights. may have looked (emphasis is on may) good when it was first done, but the kit has really started to crack, and it's looking a little ghetto/mad max like.
pretty sure it's for sale, or may have been recently sold.
spotted a few r33s last few days,
i dont rememebr teh day, but i remember seeing an Orange R33, with two black stripes up the middle of it, wing missing, looked really rough and in need of TLC
today spotted a silver r33 on the highway heaidng north just past bracken ridge.
just spotted a yellow 34 on M1 heading towards coro drive with bomex side skirts , no rear wing .. 17" wire rims on it .. anyone on here?? your car was smoking alot smelt like oil burning i hope you didnt fry your piston rings? rego was xxx.LBA
Seen too many....messed up memory...
wide body R33 yellow kessels rd....cant remember when though...
black R34 4 door going to autobarn mt gravatt
R34 coupe white on the way to the coast...gave ya thumbs up waz the passenger in my mates new civic...
seen a few mt gravatt sunday morning...cant remember - waz attending to my aunty involved in that major car crash at the lights of transport dept...
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
