Bayside blue 34 GT-T Ser 2 I presume with the rear bar at capalaba.
Didn't notice you were a "skyline" driver until you got to your car. Did pick up that you had a bit more interest in the car than the average passer.
Hi :thumbsup:
Hi :)
pretty sure I saw you at the crossing of miles platting road and logan road today
Yeah, would have been me.
Was heading to Sunnybank for YumCha :)
Where were you?
On that note, mains road, R33, SAU sticker on front. At the intersection of plaza and markets, I waved.
Pink R32 on Old Cleveland Rd East - 2 girls in it, waved.
Silver R33 on same road, a bit ahead of them, waved.
Maroon R33 - prestige plates - on Allenby Rd, waved.
Oh and 70RTY on Sunday - Grieve Rd/Rochedale Rd R35 GTR :)
Hi :D
Edited by Owgasm
Seen a maroon R32 on Webster Rd yesterday or day before in the morning, got all excited thinking it was Isola, however i got closer and it wasnt.. I was prepped and wave ready and all for ya =]
haha what a let down
There's a blacky bluey greeny weirdish colored 33 in trouts rd at the moment... at the house where the white Honda lives. It's like someone took blackboard paint, and painted their 33... very odd.
Anyone from here?
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
