red r31 skyline at the same maccas as the red r32 [morayfild road next to sizzler]
red r33 gtst at morayfield tavern [same street by the kfc]
gray r33 gtst on caboolture river road no mods most likely [very quiet]
EDIT: the gray R33 has no aftermarket exaust as stated above in fact probly no mods at all.
Edited by rb2634datto
I wasnt is the skyline, but only live around the corner and saw u on the way past! I see skylines everywhere when im not in mine ....
Ah ok.
I may be up in that area every few weekends, might see you around. :dry: hopefully in the skyline.
White 33 S2, chromies, GTR wing and a set of side skirts (400R-ish??) that were nearly scraping the ground on the Bruce Hwy this morning, damn it was low!
Was it the one with 20" chromies and the "ADHD Racing" sticker covering the entire back window?
White 31 coupe on Boundary Rd in West End at lunch time today
OLS033, tidy looking back 33 (in case you hadn't already guessed) about half an hour ago on Anzac Ave
Nah 17/18", it may have had a sticker on the back window if I'm not getting it mixed up with a Skyline I saw the other day but it was only a dinner plate-sized one in one corner of the back window. The skirts were maybe 40mm off the ground :P
Edit: can't find the exact ones but they looked similar to these: http://www.carid.com/images/wheels/zen/type-r-chrome.jpg
Nah 17/18", it may have had a sticker on the back window if I'm not getting it mixed up with a Skyline I saw the other day but it was only a dinner plate-sized one in one corner of the back window. The skirts were maybe 40mm off the ground :)
There's one from up Deception Bay way, that's running 20" bob jane chromies (which by the way, look worse than the aids infested ones you saw/posted) They're like nipple shields!) and has a massive sticker covering the whole rear windscreen. It's about a fly's dick off the ground. The guy that drives it is a complete bell end. He was a year level above me at school. Everyone hated him then too.
And whoever the pole smoker is in the maroon 33 that was doing limiter skids and tokyo drift u-turns outside the Aspley bowling alley before... Thanks asshole. I live across the road from the place and have a maroon 32. As far as the neighbors or cops will be concerned, that "red skyline" was me. :)
Edited by Isola
Actually I might have seen that one before! Well, maybe...
There's probably more than one fitting that description but a white 33 with blingy wheels and a big sticker tried to get me to race him on the Bruce Hwy one day a year or so ago, he didn't get the picture even after me indicating no followed by a good 5km of ignoring him, then tore off at a big rate of knots when I took my exit. A-class flogger.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
