passed and spotted NEO32 GTR on Mt gravatt capalaba road was in the silver 34 next to you ...
Also spotted DET33 4 door sedan spinning wheels like no tommorrow... on logan road underwood...
I think I freaked out BECKS.
haven't seen it since I said I saw it.. lol
To clarify - I park in the same parking station - that is why I see it all the time.
or you drive past as I'm walking to my car after work..
I don't hide in the car park looking at your car. lol
White 34 at uq today. Going the wrong way, had to do a uturn after the gate.
Red plates, tri spoke rims. I'd hazard a guess at Volk racing tri spokes.
Purple 33 later in the day doing a turn around at social science library place.
silver r33 with black racing stripes & body kit on the Gold Coast turned into Paradise Waters, nice!
A bright green r33 stuck in traffic in front of the mobil in surfers & a white r33 with body kit heading into broadbeach from surfers all around 5 - 5:30pm
