I've never seen a red FOUR door 34! That almost sounds like it'd be awesome.
i see one in gympie occasionally. doesn't look too bad (looks better than the red 34 2 door in town which is ruined by the fact that it's a natro with a GTR badge)
Spotted a Red 34 4 door at work yesterday (euromarque brisbane)
Spotted Pear this morning in the carpark that was Old North road, was along side you in the white 31.
Also spotted smity getting his subway tonight
Actually we passed NAK13 in our 33 a week or so ago and I forgot to post it, pretty sure it was NA (hence the plates I suppose ;) ). Gave em a wave but not sure if they saw.
Also on the way home from SCC on Sunday we saw a blue 33 driven by an older lady, had a couple of passengers including someone in the back seat who stared at us the entire time we were beside them, hahaha.
were u in the sliver gtst if so i want ur rims they look good
Nah man mine is white 33 with black rims... We both merged onto the highway at the same time and i was behind you in the far right lane till i had to change lanes to go to the BP truck stop thing
yeah man i remeber i see a different skyline everday when i merge onto the high but no one want to have a go :thumbsup:
Did you drive up Kedron Brook Road on Wednesday afternoon? Past the Holden yard?
Yep, i drive up there every arvo around 4pm MON-FRI
yeah man i remeber i see a different skyline everday when i merge onto the high but no one want to have a go :blink:
Street racing is not good :rolleyes: . Plus Im only rockin a standard GTST, stands little to no chance against a GTR =]
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
