anyone here from north lakes? was driving out of the westfield area on that highway connecting to bruce.. stopped on the lights and this VL just tried drifting in the wet..
....and crashed. badly.
was pretty funny cause he was giving me and my mates this weird look before he attempted his drift. passed by them and just shook our heads. nonetheless, it was pretty bad, the car hit the curb pretty hard. good thing it didnt rollover.
hmm.. good thing there wasnt a pole there. lol.
Originally posted by druzilla32
Do many people here drive there line thru Harrys Diner on a friday night?  Im there every 2nd friday, reversed in across from the kitchen door :P
Druzilla32 : is yours the burgandy 32? I've ben thru there in my 32 a couple of times, but I don't go in there often. Normally I'm cruising past on my way to a friend's place in Newmarket :(
Originally posted by 46n2
Druzilla32 : is yours the burgandy 32?  I've ben thru there in my 32 a couple of times, but I don't go in there often.  Normally I'm cruising past on my way to a friend's place in Newmarket :P
Yah thats me
My name is Mick, i own <---------------that BMW, its pretty schweet.
P.S. There's a guy on here with the name 002NVS, he is the previous owner on the number plates that are on my car, so any posts by him that may have caused shit are not from me~:shake:
