Saw a silver R33 going into the hope island shopping centre and parked behind the bi-lo. Its the same siver car that was at Gain's when i was last there, the exhaust tip kinda bends down. I know you on here but cant remember your nick...
Do you live around there?? We might be neighbors :P
