Hey all...
After owning my N15 pulsar for years and considering going down the path of dropping a W10 series SR20DET engine in ive decided to take the easy way out and getting a factory turbo car....
In the long run it will be cheaper and more reliable!!
Im looking at getting a ER34 GTT 2.5L
Im going to go for a drive down Parramatta Rd on saturday and was just wondering if there was anything i should look out for when looking at them, or anything in general that u can tell me bout them
Also do they have any major problems with them in any way or form
Here is a pic of my pulsar for those who may be interested
Thanks for all your help... hope not to be a skyline n00b for much longer!!!
Mick
https://www.sau.com.au/forums/topic/192336-advise-neededon-r34/
www.exciteautos.com.au or without the .au I forget.. Give him a ring, say Nathaniel sent you.. if you can pronouce my name.. He has very good deals I got my car from him .. at the time i got it no one else could offer anything close to his prices.. hes an importer for importers.. hence the cost difference..
If you want his direct number It may be on his website if not pm me and ill send it to you...
Hes in castle hill, seriously I did the whole parra rd crap too .. wasted my time all the cars where absolute shithouse.
As above, HID is a must I rekon .. btw stock HIDS are good, like i have haha :D cost a fortune tho :nyaanyaa:
Edited by DECIM8
The main thing i have come accross and ive noticied other people have had this issue aswell seems fairly common. One thing is be prepared to replace your coil packs, they will set you back atleast $500 sooner or later and thats if you change them yourself (they not that hard to change on the turbo r34's however, they are a s**t and a half to change on the non turbo. 3 the one i recently got on mine also found out a couple of other people have had this issue is the 02 sensor will need to be replaced sooner or later, this costs around 50 bucks and from what I can tell isnt that difficult to change if you know where too look. Apart from that I think the car's are pretty solid.
Can you actually get 34's with the standard HID's in them? I thought they were taken out during compliance meaning if you bought from a dealer, it would be taken out?
I bought my 34 from a dealer and it came with Xenons. its a NA R34 Sedan
Oh okay. I just assumed that because most dealers compliance their cars, they would've taken out the HID's and sell them off. Usually when you buy private, the previous owner could've changed them back.
I'd recommend the coil packs also.....I've had people giving me the "I'm looking at a car $500 less than your one" bollocks...need to keep reminding them that the coil packs *will* die and it's a pain in the ass job to do on both Turbo and N/A R34's (having done both models)
R34 stock turbo's are a little fragile, I've seen many a turbo let go under not really excessive conditions...180km/h in a stock low K car recently saw the exhaust wheel in the cat (lucky as I was just about to buy the turbo)
Xenons are great also :teehee:
Buy my car lol
when looking at an r34 check around the rear middle brake light (on the back of the boot) for rust... when looking for mine i found heaps of 34s with rust in that area.
and of course make sure the car is straight and has good paint otherwise you will be forever kicking your self when washing your ride and you find anoying little scratches and dints.
also as mentioned the factory xenons are great if you can find one with them...i was lucky.
+1 for the xenons. I bought mine from the dealers and they still had them in.
Yeah, check the body, namely engine bay and the boot area, make sure that none of the panels have been replaced.
One other thing which i should have checked with my car were the tyres. They gave me great tyres on dry, but when its wet its a whole different story.
I don't if anybody agrees, but i tried to buy a the car as stock as possible and preferably first aussie owner. Again I think its just my pedanticness (spelling). Some people prefer buying from a dealer, some private.
I did an NRMA car check as well.
rust around the rear middle brake light is fairly common for R34's, but it's not too much of a major issue for most. Just need a new seal around the light and a little bit of rust fixing.
Yep, i had to change my coilpacks, mine died in the ass. Went with Splitfires.
got my 34 more than 2 yrs ago with 36,000kms on it.
at 40,000kms replaced O2 sensor
at 105,000km replaced cracked top tank
at 108,000km replaced alternator
Apart from that, everything has been sweet! Coilpacks are still fine :P *touch wood*
Oh and I have the factory xenons too...:thumbsup: They are a must!
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
