  • Replies 142
Posted Images
  • 1 month later...
yeh f theres another gb im in too.. spewing i didnt get in with that last one!
what are the full benefits of the extractors performance? sound? fuel efficiency?
Car revs out better, less flat spots. Gives more performance in the low and mid-range. Sound is changed as well.
As there is no forced induction, you can't push more air into the engine. Relieving the restrictions in the intake/exhaust system is the key to making power.
Larger mandrel bend extractors and HP Coating helps to scavenge the exhaust gasses out of the engine quicker.
Combined with a hi-flow cat and mandrel bend catback system means that the exhaust gasses leave the engine quickly which in turn means more air can get back into the engine quickly. Air + Fuel + spark = Power. Fast air flowing through an N/A engine means more power is made. Jap engines typically make power through revs, so being able to get through the rev range quickly means that real-world performance is improved.
Fuel efficiency ultimately depends on how a car is driven. eg: I can use half a tank in a week, or in a night. It depends on how much right foot is applied.
Hey Guys,
Ok i have contacted Eug and i am just rounding up the people who are still interested in geting a set of coby extractors.
The people that have put a post up here withing the last few months i have sent a pm to and just waiting for your reply's.
Anyone else who is also interested can you please contact me asap so i can give Eug an approximate number for a bulk order price.
Cheers James
Hey Guys,
Cheers James
I may be interested, R33 GTS4 RB25DE. How much would it cost?
i think James is in the process of figuring that one out now. im not sure whether yours will be different, as obviously youl have an extra drive shaft in there somewhere to contend with...
g'day guys... sorry about the delayed response...
i've got a reply back from partsco.
all prices are subject to current exchange rate
we need 10 confirmed orders to get any sort of discount from Coby.
D12 extractors ~AUD$180-190
F124 gasket ~AUD$10-15
HP coating ~AUD$250-260
Shipping (track and trace) to Australia ~AUD$110-120
at this stage, i need 10 PM's with a definite yes to go ahead. once numbers are set i'll require a deposit to lock the buyers in, in previous buys i've not done this - however i've been caught out with people pulling out at the last minute. this deposit is refundable, only on the condition that we do not make the numbers required for the group buy to proceed.
cheers
eug
I am keen for a set for RB20 DE
R32 skyline
So im looking around $325 for a set ?
How many numbers do we have confirmed so far ... Im in talks with
Craig Saunders
Director
Partsco.com Ltd
If we can get 10 or more people confirmed as definite we will get a good discount from COBY ...
Craig has informed me that it is more financially viable to go in the group buy than it is to proceed with my 1 off order , so I may get refunded from my current order and proceed with the group buy ...
but it depends on how many confirmed orders we have so far as to weather or not I cancel my current order and proceed with the group buy ...
I currently have payed $306.25AU delivered to my door
If we can get 10 or more confirmed this number will be a lot less ...
well if your in contact with partsco then what am i doing here??
at this stage there isn't enough numbers to go ahead as what i was initially led to believe. truth of the matter is that this has occurred time and time again over the years and quite frankly it ruins it for everyone - as that's how group buys work.
people who have PM'd me so far:
hr32gts
na_beast
ShanO'
Peza
if we do not get another 6 people then it can not possibly go ahead, if Mick does decide to purchase a once off unit then we need another 7. although if numbers do not pull through, he may need to just do that to get his headers.
remember you guys asked me to coordinate this group buy, i don't mind helping out fellow forum members - but those who said they were interested but haven't PM'd me are letting the rest of you down.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
