Hey
Just saw the below kit on EBAY while I was looking for KKR turbos.
Just wondering if the turbo in that link below is an original KKR turbo, because it doesn't seem like it. The plate on the turbo in the EBAY link is different to the plates on the KKR turbos sold by Otomoto.
Has anyone bought/used one of these kits? They seem good value of money if it is an original KKR turbo as the KKR430 from Otomoto RRP is: $849 by it self.
I know the whole you get what you pay for thing, just keen to see/get more information about this kit, as KKR turbos have seen some pretty good results on RB's, and are good value for money$.
http://cgi.ebay.com.au/NISSAN-SKYLINE-R32-...VQQcmdZViewItem
Specifications for KKR430core:
Compressor inlet pipe 69mm, compressor outlet pipe 50mm
48 trim compressor; inducer 53mm, exducer 76.5mm
Turbine wheel outlet 48mm, outer diameter 64.5mm
Kit includes:
- STAINLESS STEEL MANIFOLD
- KKR430 TURBO CHARGER
- 2 BOLT 38MM EXTERNAL WASTEGATE
- EXHAUST MANIFOLD GASKET, TURBO GASKET & WASTEGATE GASKET
- NUTS AND BOLTS
Edited by abu
https://www.sau.com.au/forums/topic/192613-rb20det-kkr-turbo-kit/
like a lot of "cheap" turbochargers on ebay be aware
do some research, there are at least a dozen kkr / chinese / ebay turbo threads
most of them are full of "beware" "cheap" "crap" etc and the typicall compressor smashed wheel photos
so be warned and try at your own risk - they are cheap for a reason
there's a reason garrett charge about double for the same style turbocharger
probably due to the components, workmanship, relibabily, warranty and type of components
im no expert but i know when something is "too cheap" and $800 for a turbo sounds like this
it probably needs a few changes to make it fit
its probably more laggier and i suspect it wont be ball bearing
and its probably only oil cooled which has other implications etc
these are all covered to death in the KKR threads
have a read of all of them before forking over your money
and lastly i would recommend if you do go ahead
to have some money on the side in case of failure / engine issues
also if you do encounter problems speak to the supplier asap
do not send it to someone else or another workshop
as this could instantly void the warranty, they seem to have some wierd strict clauses on them
i mean for reference a good 2nd hand manifold is around $800 to $1000 ish
a reasonable wastegate i would expect around $400 ish ?
and the turbocharger a good reasonable one another $1500 to $2k
so yeah if the whole kit is like $1000 then it makes you wonder....
Like everything...
If its cheap, its cheap for a reason.
Also, if it looks to be priced as "too good to be true", again, another warning sign.
You can do things on the cheap ye, but if something fails (likely) then you end up paying more than if you outlayed the correct money on something decent to start with
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
