hows about timing on your car. good be seriously retarded.
but when you say hiflow, more details on what has been done to the turbo. there are hiflows and there are hilfows.
T3 with t4 internals. T3 front t4 back. And then just your mild t3 with some porting.
but always go back to the same dyno to compare.
I ran 13.3@106mph with a 2.3 60ft, with an effective power band of around 4500rpm. Straight after I had it on the dyno ,not to look at my 'power' but rather determine a problem and it showed 230rwhp odd at 4500rpm.
Rev210.. So have you had u'r car on the dyno?
yes he has.
joel,
had the car on the dyno. to examine 'tuning' (what a dyno is for). The result of which was to see a ping irrespective of afr and timing occur at 4500rpm onwards. Hence the figure (that means little) or 230rwhp or so at 4500rpm.
MRK25T,
if you are happy with the way your car drives now for the $$ spent you really don't have a problem.
Steve,
You misunderstand me.
I am trying to point out that everyone has their car for a purpose or something they enjoy doing with it. Be that the 1/4 mile as I'm on occasion enjoying or the track or just plain driving around the street. I often talk about the 1/4 mile when the individuals are interested in pursuing this as a past time.
What people lack here is an understanding of what the dyno is properly used for and what it should not be used for.
The dyno is a good tuning tool, nothing else.
I can tell you that it means a hell of a lot more to me that my car is going quicker or driving nicer after a few $$ spent on a mod than whether I can see a gain on a dyno. The fact is you don't need a dyno at all to apreciate well spent $$$ on a mod. And so far I've never used a dyno to 'back up' my mod path, I use the seat of my pants and the occasional 1/4 time improvement (a personal goal).
My example is to make you think.
On the one hand I hear all these people say(all the time) " oh thats much too low a figure for your mods, your tuner must be crap" or " I've got 200rwkw and I've got less mods than you therefore you must have a serious tuning issue".
You know things like temperature affect power figures I'm sure. Did you also know that altitude and pressure, humidity and polutants also have a great bearing on power? Perhaps you do but, I can see that most have no idea. On the polutant side even the design and wind direction in a dyno enclosure will have bearing on power generation.
The dyno is a tool. So I think if we stop telling people to compare their readings people will not continue to be dissapointed and ultimately misled. In most cases I can jump in anyones car before and after a mod and tell you straight whether you pissed your money up against the wall, cost you a sixpack ($10) Vs $90 for a dyno power run. Something I'm not as good as a dyno at is fine tuning fuel and timing for incremental (and relative) power adjustment.
A Greddy plenum is usually ~$1,750 form an Aust. dist. like Advan.
Closer to $500 off from a Jap. dealer.
Then maybe a few hundred on pipes to mate to your FMIC.
+ Labour
It's not worth it for the money but if you've run out of things to buy and want that cool look, it's the go.
I know I shouldn't buy one as I doubt I'll walk out the door with any change from $2,500 fitted but it's a weakness in me...
T.
The point is a dyno gives a rough idea of what to expect performance wise from a car.
However its sole purpose is for tuning.
No point stating that dyno readings are meaning less as they arn't.
A 100rwkw car is not going to feel quicker than a 200rwkw car.
Either you car has the power or it doesn't and this is reflected down the 1/4.
Rev210.. Your 1/4 times when compared to others have a high mph which indicates that you have good top end which is helped by quick hard gear changes. Your 60ft time isn't the best.
There are freak R33's (95 models most probably) out there as just look at Buggalugs.
Making close to 200rwkw on a stock ECU running 10psi, Exhaust and FMIC. I believe recently he ran a low 13.
When I was running 12psi, stock ecu, stock ic, 3" from turbo back he was running 11psi, stock ic, stock ecu, exhaust turbo back I would pull on him slowly. I was making 152rwkw.
Some tuners tune the car to get max power at the expense of reliabilty so that one can brag..
i.e I managed 257rwkw out of the RB25DET where as you only managed 243rwkw. etc..
The above example is a real life senario that happened recently in SA.... :)
I hope to have around 350hp @ wheels by the time I finish with my car. To achieve this I've got a trust td06-20g turbo and a wolf3d ecu to go on over the next 4 months or so (depends on how big the tax return is). By this time I expect my injectors to be running at 100% duty cycle so they'll need replacing as well given time. By the time I finish everything from go to whoa I expect my mod bill to look like $10k, that includes what I've done in my mod list below currently. The biggest stock turbo HP car in WA I've seen makes around 285hp @ wheels so if you want another 50hp ontop of what you got I'd hiflo the turbo.
Joel,
I don't think I said dyno reading are meaningless. They aren't because they are used as a tuning tool. Hence it might mean something to say ' Before I put on the spam ham hat my car had 120kw and on the same day after I put it on we got 140kw'. It might therefore be worth exploring the spam ham hat as a mod to improve power. It's pretty meaningless to quote them to others on the other side of the country as a one off.
Hi Rev, I agree in the many influences that can make a dyno readout vary greatly. Some people dont, and hopefully by reading in forums like this it might even help dispell some ignorance.
But I spose we are going to have to disagree, because I still believe that quoting dyno figures across the other side of the country is the only way to guage relative performance.
I am not talking exact numbers being gospel, but it is enough to let me know that someone with the same mods as me, plus a high flow turbo, who is making less on the same type of dyno than me (my car was tuned nose in to a workshop in the middle of summer during the middle of the day), is probably not getting all they can out of their setup. Generally as a rule, most people get around the high 100s to low 200s with cooler, ECU, boost and full exhuast.
I believe that I am right in saying that if you are getting on the low side of the above figures, and you have a highflow and supporting fuel system, then you sould be expecting more - everything else being equal.
Just about every performance shop in australia use dyno figures to support what the cars are capable of, or what sort of gains can be expected - it is about the only value that can be understood and quantified (roughly) between the coasts.
I do think bragging about dyno figures is a bit of wank, especially when you are talking only a couple of kw, but not so when you start talking large figures.
Here is an example to think about, if you had the choice of two skylines, both with the same wheels, same capacity engine, same gearbox and final drive, same driver, both started making boost at say 3000rpm, and had 1 bar at 4000rpm, but one put out peak 189rwkw at 6400rpm, and the other put out 289rwkw at 7200rpm, where would your money for line honours? If you picked the 289rwkw, then you will see the relevance of quoting figures, if not, you're a lost cause :)
I've had my car on 2 different Dyno's and the power varied by 2rwkw. Both were Dyno Dynamics.
One was at http://www.dtperformance.com.au/ exhaust the other was at RPM Performance Center.
On D&T's performance www site the VT SS LS1 Auto made around 130rwkw stock.
Originally posted by Steve
Here is an example to think about, if you had the choice of two skylines, both with the same wheels, same capacity engine, same gearbox and final drive, same driver, both started making boost at say 3000rpm, and had 1 bar at 4000rpm, but one put out peak 189rwkw at 6400rpm, and the other put out 289rwkw at 7200rpm, where would your money for line honours?  If you picked the 289rwkw, then you will see the relevance of quoting figures, if not, you're a lost cause :(
You know the problem with this example is it doesn't tell you how well the power is put down or stopped (in whatever line honour race type you are thinking of).I'd put my money down on line honours for the car with the best allround racing solution, of which a dyno reading is just 'talk' when it comes to real racing.
the dyno in no way represents the actual flow of air over the car at speed (when all this power is being used) as such it is always 'just the begining' for setting up an engine tune for racing.Far more time is spent on real track tuning than in a booth.
I would like to say that anyone who buys a car off a dyno reading is seriously lacking in common sense. What really makes you decide on one car or another is how it drives.
Historically I seen so many wheel-dyno printouts that are dubious when compared to the cars actual go factor, that I simply don't place alot of weight in them. I am talking about me actually driving them not, slow due to driver etc. Not to mention the masses of #@$% idiots who have dyno printous and flash them around with comments like " you car does low 13's and my car has 100rwhp more than you so I'd do 11's". I mean even on this forum there is no concensus on what realwheel figure will give you this or that actual performance (it's all meaningless babble).
When a Dyno reading is used to 'talk' up a cars performance or lack of it ---
--- we know talk is cheap. Lets see if it goes because a fool and his money are easily parted (see refference to 'most performance tuners').
Enough of this. I'll agree to disagree with you.
For the rest: A car is quick because its quick and not because a of a stationary dyno reading.
hehehe.... Rev210... You are definately strong headed... :(
Its a guide as its the only guide we can really use to get an idea of how a car will perform.
Sure the power can be fudged but any one in their right mind with a little bit of knowledge will know if the reading is 'around' the mark.
Stubborn on this one, for sure mate.
If its a guide , I don't have a copy. If what your saying about it being a guide is true would you care to post 'the guide' so we can see how good it is. The fact is I'm not in my right mind and I have no knowledge.
I think if you look at the facts, there is no 'guide' to be found in peoples miss mash of dyno readouts. The only guide built in is whether a given mod will or will not improve power, relative to that day and car's readings before and after. The magnitude of the gain and the total amount of power quoted is moot.
Steve.
Yep I'm officially a 'lost cause'. I think because I've stupidly done everything myself for too long, I should have stopped at rebuilding 13B's but, no I had to keep on making life hard for myself. In the process I became able to tune things without using a dyno and do a better job than those that did on some occasions.
My best comeback is this....
For every 1 person like me there are at least 100 others who use the dyno , think the figures important, spend 5 times as much money for the same 'real' power and have their ass kicked by the that same 1 person.
13.3 so far buddy. Do you belong to the 100?
OK, let me be the first to bite:
R33, mods;
600 x 300 x 76 FMIC (hybrid)
Pod (K&N)
3" full exhaust (N1 type, cat in)
Power FC
EBC at 0.85bar
first tune 189rwkw - afm voltage peaked at 4500rpm
second tune 203rwkw with Z32 and non slipping clutch
as a guide
Hope you didnt take my lost cause comments the wrong way, sorry at what was only meant as a friendly dig I didnt mean to offend. I agree with most of what you say, its just that I see another use for dyno figures, like Joel and others no doubt, beyond what you do - my bad
Mark,
I reckon you just go for some bigger injectors and wind the boost up a little more - That will get where you want to be no problem at all.
Forget the Plenum, for the moment - it's a lot of money for only a bit of gain.
I share Blitz's thoughts too - be very very careful about who tunes it - they should have an outstanding reputation for tuning skylines.
As I have been reading and seem for myself first hand - When you go fiddling with too much more power, things can go phuuupppt.
Cheers,
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
