depends on how bad it is...the prefered method would be to get it professionally cut out and resprayed..I've got a spot as well but its on the inside of the bootlid...got quoted bout $400 to cut and reweld and respray the whole bootlid...which is about the same price of buying a 2nd hand one...
https://www.sau.com.au/forums/topic/192698-r34-rust/#findComment-3461570
The rust around that area is bloody common isn't it. Why's that? Does water get trapped behind the brake lights easily or something? Would you use some sort of silicon around the light to stop water from getting to that area?
https://www.sau.com.au/forums/topic/192698-r34-rust/#findComment-3462340
i reckon water leaks quite easy through these areas due to rubber seals drying when out coming from Japanese to Australian climate conditions.
i have the same problem next to my spoiler on my boot lid. 33 though :D
https://www.sau.com.au/forums/topic/192698-r34-rust/#findComment-3464680
lol, i was thinkin of mayb jus pullin out the light and givin it a light sand to remove the rust, i suppose that would give me the chance to check the seal too, if it is the seal that is shitty, does any1 know where i can get me another one?
https://www.sau.com.au/forums/topic/192698-r34-rust/#findComment-3465368
rush can u show us a pic mate ?
https://www.sau.com.au/forums/topic/192698-r34-rust/#findComment-3466405
as for ya getting the rust sorted; bring it to a few reccommended panel beaters and get a quote from each of them on getting rust cut out, re-welded, and boot resprayed. go with which ever one youre happy with.
there are short cuts that panel beaters can take from welding - ie - bog job, but if not done properly, rust wil return in the near future thereafter.
if ya do get this procedure done, get them to strip that spoiler as well! :worship:
https://www.sau.com.au/forums/topic/192698-r34-rust/#findComment-3478510
  • 8 years later...
Hi guys
Sorry to bump a very old thread but I have a valid question.
I have the smallest amount of rust which has appeared on my R34 GTR. As per thread, the surface rust is on the right-hand corner of the center brake light. I will eventually remove the light and get rid of the rust. Does anyone know where I can buy another seal for the brake light from? Or what would be suitable substitution for the foam seal around the light?
Cheers
https://www.sau.com.au/forums/topic/192698-r34-rust/#findComment-7701680
Make sure to fully dry the area after washing the car. That area traps water, same thing is happening on my 200 and the 34
Yeah, I know now for sure. I've only washed the car once since I've had it. That's when I actually noticed it.
https://www.sau.com.au/forums/topic/192698-r34-rust/#findComment-7701730
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
