  • Replies 47
  • 1 month later...
So this arvo a mate and I went at it to try and put in my HKS Cams, HKS Cam Gears and Greddy Rocker Stoppers!
Before :
And thats is it... there is no after cause we had to bail out, the cams I got came out of a Black Top SR with VCT, I was told that the cams should still fit in a Red Top SR but we cam across a slight problem. The cam bolt the bolts the cam gear onto the actual cam itself does not go in the cam due to the cams being specified to go into an SR20DET with VCT and the bolt is to big, So my question is can I retain the cams and use a cam bolt out of an VCT SR20 cut it down in size ( as they are longer to go through the VCT etc ) and bolt up my cam gear and put my cams in and done? Or do I have to get cams to suite Red Top only?
Bit of a bummer cause after cams were done everything else was going to follow and wiring also pretty much, now I have this problem... will be a pain to buy brand new cams when I had plans for other things.
https://www.sau.com.au/forums/topic/192746-jdm32/page/2/#findComment-4389243
No one wanted it so I kept the thing... still think i should of flogged it off... oh well. The Lobster was all done in Japan and came with the SR when I bought it but I eventually sold the FMIC kit off to make way for other things.
https://www.sau.com.au/forums/topic/192746-jdm32/page/2/#findComment-4390424
  • 3 weeks later...
Blitz Top Rad Hose and Apexi EL2 Fuel and Oil Press Gauges
CUSCO Rear Strut Brace
KTS Rear Sub Frame Brace
KTS Rear Camber Arms
KTS Rear Craddle Mounts
Silk Road Craddle Brace Kit
Kazama Rear Toe Arm Brace
Front Chassis To Front Reo Brace
BOSH 023 Fuel Pump
SARD Fuel Regulator
More to come :P
https://www.sau.com.au/forums/topic/192746-jdm32/page/2/#findComment-4453645
  • 4 weeks later...
i have been doing research about dropping a sr20 into my track built r32 for a while.
i currently run a r32 rb25de + t and we decided to a ) wait untill that pops as its been going strong and B ) put a S14 black top in as they are a better motor but that makes the whole job more expensive.
i also have the D-Max rear boot spoiler and roof wing the roof wing is yet to be painted and fitted. fitment on both the items is spot on. you really do get what you pay for.
about the only thing i would change now would be the front bar as i find the GTR bar just doesnt match any other kits. i have a full GTR front end on mine and we fitted up a B&N kit and then took it back off. i have gone back to stock GTS-t side skirts as they match the look better.
also what is that very JDM looking part on the back of the bonnet? what is it called or who makes it ect?
sorry for crapping on its just this car is very similar to mine althoe mine is 2 door.
https://www.sau.com.au/forums/topic/192746-jdm32/page/2/#findComment-4500158
Nick, if you buy it, I'll bring it down to melb from brissy for you when I drive down... sometime, as long as you're not fussed on waiting for me to drive down (could be a month or so).
I gotta bring the ceffy down and bring the R32 up sometime soon once its out of the workshop.
https://www.sau.com.au/forums/topic/192746-jdm32/page/2/#findComment-4519840
    • Had a go at the stuck crush tube this afternoon. Tried things like grips and a chain wrench first but wouldn't just twist straight off. So got to work with a drill. Started small and kept a depth stop on to make sure I didn't drill into the bolt. Made a line of drill holes all the way up and enlarged them. Then a combination of chisel and Dremel to split it all the way up. Levered the split to get oil in there and eventually it gave a bit while levering. Worked it back and forth with loads more oil till it was spinning freely, then with grips I could work it downwards and off. And no significant damage to the bolt (not by me anyway - just the 27 years of rust)
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
