Hey guys and girls
Looking for some cars that might have the goods to go into either HPI or Autosalon Magazine.
Please PM me a pic and some details as I need to run it by the editors first.
Then if all looks good will go from there with what is the next step.
If you also know a business that has a project car that is completed and needs some free publicity from the exposure PM me and will take it from there.
Please keep in mind this needs to get approval through the editors!!!!!!!
Thanks all
https://www.sau.com.au/forums/topic/192788-what-does-sa-have/
  • Replies 97
Dan Dan Dan...
There seems to be more highly modified R32's these days. All seem to be running RB30DET's. :)
Mines a set of cams away from 300rwkw on fairly low boost. Fingers crossed I get to 340rwkw ish with water injection on the GT3076 .8. :)
I like to look at cars that are different; something that's a little different doesn't have to be pretty.
I get a little tired of reading of cheque book racers that look pretty or the same setups over and over.
I prefer something that's a little more home grown.
Possibly with a sponge or 3 thrown in there hey Salad. lmao :thumbsup:
Dan Dan Dan...
There seems to be more highly modified R32's these days. All seem to be running RB30DET's. :thumbsup:
Mines a set of cams away from 300rwkw on fairly low boost. Fingers crossed I get to 340rwkw ish with water injection on the GT3076 .8. :P
Nice one joel..... hows your gearbox gonna handle that???? rb25 gearbox....
