I am after a standard RB25DE intake manifold/plenum with all idle gear, throttle body, cross over pipe etc.
Let me know!
Thanks
NOTE: Aftermarket plenum no longer for sale
Edited by drunkenmaster
https://www.sau.com.au/forums/topic/192849-wtb-r32-rb25de-inlet-manifold/
Willing to trade (with cash adjustment) for my RIPS front facing plenum and large throttle body.
I beleive this is only one of few aftermarket plenums available for those chasing power gains on their R32 RB25DE style heads on RB30DET conversions due to short runner length.
Straight sale is prefered though.
Let me know!
Thanks
i have a complete rb25det plenum and a complete rb20det one which i belive is the same as the 25de if this is of any help.
[email protected]
ive got a top half of a rb25de from a r32 and TB
but no idler
what sort of cash adjustment are you after if i could supply the whole lot? and reason for removing the RIPs plenum?
and do u have pics of it?
Thanks
john
but no idler
Thanks
john
Sorry guys, no longer trading the plenum.
The reason I wanted to remove it was I am having engineering certificate troubles, however I think I have found a way to get it through.
I have also found an RB25DE manifold as a plan B, so I guess this thread is closed.
Sorry for any inconvenience.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
