  • Replies 96
Posted Images
Remote is all sorted now with much thanks to /2on, just wondering, for ppl who have installed this and got it working, do you have to mount to eji unit flat and level, im assuming so as it has a g-meter in it and i doubt it will work if i mount it vertical, unless i roll which i dont plan on doing.
Ask nightcrawler or michael their the only 2 people i know who have or had these.
Ps i just noticed your car looks almost identical to mine asides the rims and now we both have the same dash......scary :P
Edited by /2on
Now i have yet another problem, i put the dash in today, all went well apart from the speedo now says i am doing a little over half the speed im actually doing, i removed my avcr display when i put the dash in which i know was only 2k's out, so i plugged it back in to check the speed and now my avcr is doing the exact same thing.
The only thing i can think that i did wrong was when i wired it up one of the wires i hooked into was not the actuall wire off the ecu, there was a wire coming off the ecu wiring going to the avcr so it was easier to just use the avcr wire to tap into, im not even sure if it was actually the speedo wire that i did it with, any idea if this could be the problem, or any other ideas what it could be?
Found another Option to the EJ1 and HKS Camp, Blitz have released their R-VIT DS which connects to a display
Looks good, but from what i can find it seems to run off the ODBII port, which i know 33's dont have.
lol!
yes they are pretty cool ;) its a limited edition nismo dash with the option of sat-nav or epson ej-1 driving emotion system. they are extremely rare, they come up on yahoo-auction very rarely, and the dash normally sell upwards of 60,000yen and then you need to find the epson ej-1 system which can sell upwards of 40,000yen
the epson ej-1 system display information like, speed, rpm, g-force, power, torque, lap time, fuel eco etc etc
here some photo of mine
and some details on all the info it can display
thats awsome I think nismo makes ones for the gts-t as well.
  • 10 months later...
I have an Epson EJ-1 computer system for sale if anyone is still interested. Full setup, everything you need, includes remote, wire diagram charts and installs in a matter of 30 min. by tapping 6 wires on your ecu. Any ecu compatible, I am running Power FC on my 33 GTR. This will work with many, many motors. The list is in the instructions. I sold my GTR and took this out cuz I loved this gadget. Displays to ANY monitor with rca video in, doesn't require and does not include the Nismo lcd cluster. Located in the US, will ship world wide once confirmed payment of $450 usd Any questions, please email [email protected]
http://picasaweb.google.com/lh/photo/KvTlh...feat=directlink
http://picasaweb.google.com/lh/photo/l7TK2...feat=directlink
  • 2 months later...
old thread...but i love my EJ1+nismo dash hahaha
one problem though, everything seems to work OTHER THAN g-force screen and speed screen which shows nothing. ontop of the speed screen not working, my odometer is not clocking over, but the speedo and tacho works fine :S help?
  • 1 month later...
SOLD
im sure this question has already been asked but would one of these fit and work in an r32 gtst at all? ive never heard of these things until tonight, they look pretty kool
Obviously the dash its self would not fit but the ej1 may work, it has jumper settings on it for different engines so it may work with a 32, the output is just an rca so it will hook up to any aux input on an in dash screen.
  • 3 months later...
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
