ive searched and all i can find is threads on fuel rail or fuel pumps etc, nothing on the actual fuel lines...
Just curious to know if anyone knows confidently the limitations they have/if any?
i have 600rwhp in my car t04z rb26/30, running surge tank, 1 internal pump, 1 external pump, 700cc injectors, a/m twin entry rail
cheers...ben.
https://www.sau.com.au/forums/topic/193214-stock-fuel-lines/
I think it would depend on how much pressure you are running thru them.
If its near standard base fuel pressure then i think perhaps u should only refresh the factory items :D
Also i take it we are talking about the rubber lines and not the metal ones that run upto the front of the car?
I assumed he was talking the flow potiential of the metal lines that run up underneith.
You cant really just keep piling up the base pressure, as 45 + 30 max = a fair deal already.
Yeah i think its best to keep the base fuel pressure stock, and was saying if the rubber lines are in good condy they should be ok.
id be fairly interested to see what people think of the stock lines as well, stock line i should say, im going to be running twin 044's, i dont know if i should join them together into the single stock line or run an extra line the same diameter as the stock line for the 2nd pump?
...but i dunno
Sounds like you need an excuse to run some under car hardline and fill Mr Speedflows pockets a little more ha :) Your car is already off tap crazy gurl.
Id hazzard a guess that very few of the big HP cars in the "SAU Dyno" threads run larger lines, i reckon your fine.
Edited by GeeTR
If your (needing to) run twin 044's in the first place, injector fuel distribution is prolly guna mean your running a AM rail (6x 700cc+ inj's, long rail, good idea) with twin feed... possibly.
I'm too lazy to do the math, but when your maxing out a 044 pump and need two, possibly you'll reach the limit of the standard steel lines. When you get there, 800rwhp+... $100 max worth of hard line will be the least of your issues *evil laugh*
the twins are more of a precationary approach, and yes gunna be running am fuel rail etc, may as well just add another line the same size as the standard one ;)
Instead of having 2 delivery lines the same as standard, why not just have one bigger line?
Im running an RB25 in a datsun and had to upgrade the line (factory datsun lines arent very big) so i put in a 3/8 line (8mm) and the standard skyline lines are 5/16 (6mm), just to be safe.
  • 5 months later...
my engine is getting put back together as we speak and im at the stage now where i need to sort out the fuel system. Already have x2 044 pumps, surge tank, fpr, a/m rail and 1000cc injectors. I was thinking larger rubber ones in the boot and larger metal underneath up to the front and use standard return. As mentioned, will join two pumps into a single larger pipe be a good idea? Power goal of 700rwhp. Can i get some recommendations/feedback?
cheers
I used the 2 factory lines to feed either end of my rail and connected a -6 braided line to the regulator and ran that back to the tank.. I run two nismo's intank so its nice and quite better than the old smelly, noisy twin 044's with mass of pipes in my boot...
  • 1 month later...
people say that the standard lines will do for big power some say they wont..for the price of running new lines, think it cost me well under $70 to run 3/8" all the way, then why not do it...peice of mind plus running 3/8" line means having nearly 20% more size over the standard lines.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
