OK, I didn't confirm anything with Stuart yet as he is booked out until next week. My best bet at the moment is to organise to get the guard rolled by Stu and get my rims back from the tyre shop for safe keeping at the moment....
First off, is there anyone else other than Stuart that can do it this week?
Des at AutoFx rolled my rear guards and a mates PERFECTLY took him no time, he will also come to you. Good bloke too, he can usually roll them with a day or two notice. Hope this helps.
Des: 0412 034 861
Take it easy
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
