Lousy news guy did you stil have a 32 crank or had you updated the oil pump drive etc?
Believe the crank angle sensor from a 34 is different to a 32 and the end of the crank is physically different to suit
This being why there is one PowerFC for a 32/33 and a different one for the 34.
Sure someone could fill you in on the other differences,
or correct me if I is wrong.
https://www.sau.com.au/forums/topic/193729-engine-go-bang/#findComment-3475335
LOL i pulled it back from 5th to second by mistake from about 255kph. was well over 10k rpm showing
And to the old girls credit she is still running with no oil pressure, not to mention it had over 100,000kms on the engine anyway.
Thoughts were to remove this damaged engine and throw another stocky with the 2860 turbos in for the next race meeting while the damaged engine is at the rebuilders. i have about 2 weeks and not sure we can get the engine rebuilt in time, the builder has a few in front of me to complete.
https://www.sau.com.au/forums/topic/193729-engine-go-bang/#findComment-3476142
you are kind of right. GTRs don't have a crank angle sensor. they have a cam angle sensor. The camshafts are slightly different, and the cam angle sensor is different. Yes the crank is a little different too, but that has nothing to do with the sensor, it just has larger 'flats' to drive the oil pump gear (which presents no problem).
that is all I can think of off the top of my head.
https://www.sau.com.au/forums/topic/193729-engine-go-bang/#findComment-3476765
Yeah figured some one would correct me, my bad
and in my description where would ya put the balancer?
It must a been late in the night :P
https://www.sau.com.au/forums/topic/193729-engine-go-bang/#findComment-3477277
yep oil pump drive failure!
But very lucky, no damage to the crank must have been circulating some oil at least. All the bearings were in good condition a light polish on # 1 big eng gernal and back in she goes.
Not a nice job getting engine out for the first time with a pull type clutch
https://www.sau.com.au/forums/topic/193729-engine-go-bang/#findComment-3493110
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
