Hey,
Just abit about what i've done.
Sold my R34 GT-R Brakes a while ago and fitted a complete brake set from a Mercedes-Benz AMG.
I got 8-Piston Monoblock Brembos and 4-Piston Brembos from it.
Also 365mm Rotors for the front and 355mm Rotors for the rear.
Brackets were custom made and designed to fit as the Merc brackets weren't suitable.
At first the 18's wouldn't fit, but managed to get them over now with a bit of room to spare. I think it looks better than if i had 19's on as the brakes fill the rims nicely.
What do you all think?
*No Sour Lemons please. Pm me for that stuff.*
Pics while fitting:
Test fit rim with SSR 18s x 11s
Then recent photos with current 18s.
Enjoy :(
  • Replies 49
That's some hardcore brake pr0n - nice one.
Why did you choose this setup over one of the high end bolt on kits? A bit of adventure?
i like. excellent to try smething differnt.
questions
1. $ front, rear, and custom brackets (PM me if you want)
2. bolt pattern the same?
3. rotor thickness front and rear
4. master cylinder changes?
5. what's with the valves on the black wheels being truck valves that face inward? lol
nice.
as coincidence would have it i just spent last week on the phone trying to track down a set of these to do precisely what you've done. nothing available, even o/s. you must have better search skills.
or an ebay account
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=320180032411
Thanks all for the comments.
MrKotter:
Chose this setup cause it was something different, thats why i didn't re-paint them and change the look. I wanted to show where they came from :(.
High end kits? I prefer these, i know the quality must be superb, real brembos and from the weight of mercs, i know they should stop any car with ease + they are 8-piston and 4-pistons anyway.
Ronin_09:
The bolt patterns were/are the same. Didn't need to modify the rotors.
Not sure how thick the rotors are but will measure when i get the chance.
Mastercylinder didn't need changing.
LOL. The valves, don't ask. Nothing wrong with inward facing valves ;)
Mr Keets:
Yeah. n00bs - wtf is that? Must be a E(uro)-Spec.
Scooby:
Keep trying, they will turn up. Try getting the rotors as well.
or go ebay like FunkyMunky.
FunkyMunky:
No rotors there.
Cheers to all!
Noooooooooooo! I just bought a Brembo F50 front kit on Jap Yahoo.
Simon I agree, keep them the way they are; if it's good enough for AMG it's good enough for the GTR. Can I ask how you went adapting the handbrake? Not sure of the AMG offset but the Falcon GT-P and Viper SRT10 rear 355mm disc offsets are similar to the GTR if you need discs down the track.
Edited by Scooby
The handbrake had no problems whatsoever. Remove and re-attach as if you were replacing.
Are the Brembo F50 kits any good?
That's amazing. I got hold of a new F6/R4 Brembo BA FPV GT-P set up and while the front was going to be relatively simple the rear disc offset was a lot different. In the end I decided I'll onsell them at some stage. Nice brakes though. I got quoted $1000 per end to have caliper brackets made up for the big Brembos, that was part of the reason for deciding to move them on.
The F50s are OK I guess, biggest 4 pot I'm aware of and run a 355mm disc. They are on the BA GT-Ps also. The thing was the kit comes with two peice hats and Brembo brackets, so it's a drop-in fit.
Owgasm
how far do u have to push the brake peddal befoe it goes hard ?
did u change your master cyl ?
Before the brakes lock up/are in motion or like as far i can push until i can't anymore?
master cyl wasn't changed.
$1000 per end :ermm:. Geez.
I see why you sold them.
The kit is all round or just fronts?
sorry to ask a stupid question.. but are the rotors back to front?
don't you want the curves of the vanes facing backward, rotationally, rather than forward?
You got me all worried. Got me thinking hard. Looking at the picture.
The right rotor is rolling ->> that way. therefore the vents are facing / . I think thats what i've placed it as.
Hard to explain. But i think its correctly done already. Else its just a very late night already.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
