Hi everyone,
Wondering if i can get help on a little problem i had with my cars transmission.
Car: R33 Gtst S2 97'
My current modifications to the transmision include:
-Xtream Racing clutch, (1200kg clamping pressure with brass button sprung centre)
-'C's Shortshifter
I think everything else is stock, i don't know much at all about transmissions and those came with the car when i bought it.
Before, anyone comments about what i was doing. lol. I have to say it was 'legal' and yes i was an idiot (which i fully admit).
Just a few nights ago, i attempted to do my first burnout on the car, and as i didn't know how to do one,
I just reved the car high about 5-6 thousand and dropped the clutch, when i hit the rev limiter which is set at 6750
i shifted into 2nd and continued to kick the clutch slightly and give it, once again hitting the rev limiter and holding it.
Which was a bad mistake :glare: .
After that i didnt hear any unsual sounds, although 2-3 minutes later my car could not shift into any gear.
It just kept jamming, whether the car was on/off or rolling.
After about 15 minutes of trying the car finally started to shift although felt different, as in the gear shifts felt softer than usual.
Just wanted to know, is it a major problem which i should get checked out immediately, as the car is running well at the moment,
or is it a normal occurence, and only screwed up due to me not being able to do burnouts?
Help is greatly appreciated.
Thanks alot.
https://www.sau.com.au/forums/topic/194115-shifting-problem/
were your wheels spinning or was it just the clutch, any bad smells coming from the clutch. i am in the process of replacing my extreme as it wont hold when i put my foot down overtaking at higher speeds (80-100). started out exactly from what you were doing but down the drags :D p.s. can still change gears ok.
Edited by Pal
were your wheels spinning or was it just the clutch, any bad smells coming from the clutch. i am in the process of replacing my extreme as it wont hold when i put my foot down overtaking at higher speeds (80-100). started out exactly from what you were doing but down the drags :) p.s. can still change gears ok.
At the time, i dont think there was any clutch smells,
the wheels were spinning, but not smoking up greatly.
At the moment i am not having any problem at all with the clutch or shifting,
i think it was just at the time, although i am still going to get it checked up.
At most, it probably jerks a little harder than usual when the clutch is cold however it runs near perfect when it warms a little bit.
Also another question. :) .... My engine stops running in some cases and the car just stalls. For example, if i am rolling the car at whateva speeds and do a really slow shift i.e. hold the clutch completely down for a good 6-10 seconds whilst in gear and rolling, the engine turns off.
I think it might be a result of my above mistake.
Dam i wish i didnt have work :) dont get time to drop it at a mechanic...
I the time.. I think it was just theat from the burnout..
To drop a clutch at 5-6K is VERY hard on the clutch.. even if it is brass button!
I noticed the same with mine.. after big clutch drops.. it will become "sticky" and have problems engaging/disengaging due to the heat.
Have it cheaked out just in case though..
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
