  • Replies 55
Posted Images
Daaamm dat sheet is JDM tyte y'all..
lol like i have never before LOL
dang..jeri lee...too bad i aint goin..anyone going with room in their boot?? lol
two choices...
1. bring me
2. bring jeri home to me.or nikita shes dang hot too lol
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
