Hi All,
Wondering how many PSI i could run in my r33 GTST. I am planning on getting a boost cut defender (short term until I get a PowerFC).
Mods are:
  • GReddy front mount
  • GReddy Profec 2 Type B boost controller
  • 3" stainless dump, Gutted Cat, 3' Stainless TRUST exhaust
  • K&N hi-flow panel filter
  • CGC Hi-Flow turbo
The rest of the car, engine is standard... How much boost could I run with the standard injectors and fuel pump without it being dangerous???
Cheers
Thomas
https://www.sau.com.au/forums/topic/194309-how-much-boost/
Get a ECU, get it tuned, and get a fuel pump
Aftermarket turbos with proper management and decent fuel provisions = absolute danger/motor death for SURE.
You risk your motor due to the fact its not tuned for the turbo, and your running the stock pump.
Two very big no-no's mate.
So either run as little boost as possible, or go and spend the 2k (ECU/fuel pump) and get it setup at lease half decently.
I say half decent... as you still need injectors/AFM to make the most of that turbo.
So all up you realistically need to spend another 3-3.5k to actually use the turbo you have fitted.
https://www.sau.com.au/forums/topic/194309-how-much-boost/#findComment-3485070
So, if I leave the boost controller turned off and run the standard 7pound setup should be safer for the time being??? Haltech or PowerFC?
Edited by nuclear_skyline
https://www.sau.com.au/forums/topic/194309-how-much-boost/#findComment-3485285
Where are you located?
My recommendation... BCD are bad, they clamp the AFM voltage which makes your car run dangerously lean, and also leaves the ignition too advance for your desired boost...
REMAP FTW IMO, Next option would be a PFC, or then complete aftermarket.
https://www.sau.com.au/forums/topic/194309-how-much-boost/#findComment-3487417
id really go get it tuned before you do any real damage to the engine, driving it now with a bigger turbo on and the standard pump is skating on thin ice.
but thats just me...
CJ
Edited by -_-StRyDeR-_-
https://www.sau.com.au/forums/topic/194309-how-much-boost/#findComment-3487463
I GET IT!!!! I'LL GET A PUMP AND COMPUTER!!! (didnt have any choice bout the turbo, mine shat itself and I needed a new one)
I'm looking into the GReddy E-Manage Ultimate. Anyone had experience with it???
https://www.sau.com.au/forums/topic/194309-how-much-boost/#findComment-3487536
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
