I have an R33 GTS that has been written off due to being t-boned. Although the car is not worth getting fixed the damage is not actually that extreme and only the rear quarter panel and suspension has been taken out. All the rims are still okay and everything else inside and out are in good condition.
Anyway looking at $4500 ono for the entire car as is...
Edited by MSPEC
https://www.sau.com.au/forums/topic/194345-wreaked-r33-gts-1995-s1/
How many KM's has the car done?
I have money ready to transfer for gearbox delivered to SA
Not sure about ks will have to check. Looks like I am going to have to pull the car apart. I will arrange to get all the parts removed asap.
Hi there, any chance youve still got all for springs for your ride. If so how much would you be will to part with them. Also, i take it, from the pics, that they havent been compressed/lowered previously. Kind regards, Evan
does it run and how many ks has it done let me know
might be good for project car i am looking at building
The engine runs fine but the rear right hand suspension is fooked.
128000ks on the clock. The car itself is in great condition inside and out (with the exception of the crash damage). The car was fully re-sprayed a year ago.
Edited by MSPEC
4 stud hey
umm i know the suspension and panel at the back there are pretty bad
but are the mounts for the suspension at all dammaged??
and is it posible to transefer suspension from a 5 stud s1 gtst into this car??
4 stud hey
Not sure I am no expert on this kind of thing ... you would have to come and inspect the damage yourself.
well i will look into it
what would you want for the bare shell
no lights no doors no boot no front guards no bonnet nothing just the bare shell
Not sure I am a while off getting that far but what ever it is worth I guess.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
