As title suggests I'm after a vg30 turbo aslong as it has a steel exhaust wheel as i want to run a little more boost than a ceramic wheel can safely supply.
Must be in good working order, have cash waiting.
Please PM if you have anything of interest.
Edited by HR31_RB20DET
https://www.sau.com.au/forums/topic/194353-vg30-turbo/
I have a VG30 turbo for sale (with the OP6 exhaust housing). I don't know how to confirm that it has a steel wheel. You can come and have a look at it if yuo are in Sydney.
https://www.sau.com.au/forums/topic/194353-vg30-turbo/#findComment-3487565
Ah ok, i'm in Brisbane.
I might see if I can find some information to help identify which batch of vg30 turbos came out with the steel exhaust wheel.
Thanks.
https://www.sau.com.au/forums/topic/194353-vg30-turbo/#findComment-3488729
  • 1 month later...
