parts i want gone asap
trust catch can $80 SOLD pending payment
trust oil cap $35 SOLD
trust rad cap $20 SOLD
trust AIRINX 4 a skyline new filter $90
apexi AVCR $400 (never had boost bit hooked up only screen) SOLD
apexi rsm $180 SOLD
trust elec. boost gauge $150 (small one)
momo steering wheel with boss kit $200
momo pedals $80
hybrid intercooler with trust RS bov $700 (r32 an r33) SOLD
cusco strut brasez front $120 rear $120 SOLD
TEIN super street coil overs 4 GTR AN GTS4 r32 $1500 (no more than 900kz old)
17" gold drift teks with shit rubber $650 with swap over for ur standard rims SOLD
hks dump an some stainless front pipe (front pipe replaces cat as well) $150 SOLD
cat bak straight pipe with twins at end $150 SOLD
sparco JNR retrim in blak vinyle $600 for pair SOLD
bottom mount bride rails $400 for both SOLD
if u want the sparco on the rails can work out btr price
trust titanium wheel nuts $150set (there are 20 of them)
trust 2 gauge piller mount $100
JR front bar painted yellow few cranks can b fixed easy $100
pm me if u want parts they are all pik up only from down south or cant meet u in the city if u live north
or call me on 0417884805
Edited by 4dirty2
https://www.sau.com.au/forums/topic/194393-parts-to-go-asap/
yyeepp its stok as of tomoz im sik of ppl cumin an sayin ohh cant buy it too loud blah blah even thow they gett all the standard parts
so yeh kye if theres anythin u want tell me an well work it out
some people man, i know the pain of selling a car too :P
will have to work out a few things and let ya know. im interested in the dump pipe, is it a 3"?
cheers dan
Edited by Import S13
are the drift teks 9 hole 4 x 114 and 5x 115 or 10 hole?
and what do you mean swap over for standard are you expecting rims in return?
thats a pretty cheap price for a full set, with tyres, even though they are thrashed, so id say he means 4 stock wheels+$650 for the 4 drifteks with tyres.
on another note;
are you selling the car bone stock? no kit etc?
hey mate,
couple of questions, are the wheelnuts security ones? and is the front bar that you are selling the one in your avatar? i googled a few combos of jr and front bar and just got pics of some rednecks bar in their entertaining area LOL, if u could post up a link or something that would be great
Edited by bezender
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
