R35 Gtr - Costly Rebuilds At 100k - Fact Or Fiction?
haha this is funny shit
honestly, i know what you read, but think about it logically..
why would nissan make a car with so much R&D in it but make the engine expire in 100,000kms?
logic is a great thing sometimes.
(what i'm trying to say is its all a load of shite)
Yeah it didn't make any sense to me either, but i thought i would throw it out there to see if anyone else had heard of it.
By the time the R35 becomes a as common as 32's or 33's.. There will be more and more manufacturers using this technology.. this means that more and more workshops will be offering this service due to the demand..
Technology will advance.. support will be offord..
when the GTR becomes cheap enough for many of us to afford.. it will common practice..
thats even if it is true!..
And lets face it.. The RB26DETT that is nearing its 21st birthday costs 6K.. which means the 35DETT will have to cost more.. lets say 10K.. its not going to cost 10K to service an engine at its 100,000km mark..
thats just silly
thats my 2 cent
Edited by GTS4WD
Still... servicing the R35 is cheaper then all other cars that do 100kmh in 3.5secs i'd imagine. I heard all the new Ferrari's require a 100k service every 20k and that the belts must all be genuine parts. I think what we're forgetting here is that once the car is here, the R35 is a pretty exclusive "super" car with matching performance. I wonder how much the 100k service cost for a 911 turbo....
was it in the motor mag or wheels that said it???
Either way dont take everything they say for granted.
YEah, but you dont have to shoot the mesanger, I was just stating what I read, it could be buls%$t, I dont know. It was in the december issue of Motor mag.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
