  • Replies 116
bump, more parts added/updated, split things into groups to make it easier to read
Chassis has subframe, rear window, rear quarter windows, would be good for a rear cut or something
Also has engine plate/compliance plate, car not listed as a writeoff or anything
$500
or $680 delivered via tow truck to your door SA metro only
if not off to SIMS metal or similar
Hi I am chasing a drivers side rear QTR window and shipping to Darwin.
If you can cut it out let me know a price with shipping
Regards Devo
$500
If I have to cut it out myself I'd want $90 for the driver rear quarter window this is including delivery to you in Darwin
need to act soon may be going to wreckers this Wed
hi im interested in cluster surround wot does it include pic preferably i will forward 20 bucks ur way is it a series 2 cluster
bank details
Hey man just wondering if you had this clip?
sorry sold rear wiper and motor today, brakes are not for sale
shell looks like it's been sold now as is
cluster surround is just the plastic piece that sits in the dashboard in front of the cluster (ie surrounds the front of it if you get what I mean), comes with screws, all parts from a Series II (the actual cluster/odometer has been already sold)
Hey, was wondering if you'd split the interior trim so I could get just the driver's side A-pillar trim? Mine's got some rather horrible holes in it from the previous owner installing a boost/AFR gauge.
the A-pillar I have also has 2 or 3 screw holes in it, make an offer
seriously if you want me to split gear up make on offer, my prices are up there as is and some bundles are fair cheap already, if you need things broken up then make an offer at the same time
sorry front windscreen smashed
ok would u be able to send it to melbourne give me bank details and tell me wot i should put on the remitter and i will pay
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
