Hay cara..
You couldnt of made them any smaller? Their a bit big.. I see too much :)
Looks like in the third one.. you lost some high mid (if that makes sence) power.. What mods were done in the second and third?
What was goin on with your car in the first one?.. its all over the shop! Slipping clutch? Missfire?
Edited by GTS4WD
https://www.sau.com.au/forums/topic/194796-dyno-graphs/#findComment-3491390
hmm... you can notice the VVL making the range much chunkier, it's quite cool.
i'm with Cris, the first graph is near useless - i'd hardly use that as a benchmark to call the 16kW increase. you have two runs, neither are alike (done in different gears?) and the AFRs are all over the shop for what should be stock. with proper AFRs i would have said that you would have more power in the first run.
2nd graph is a little better, but again different graphs in both runs??
3rd graph is very nice... and i agree, looks like you lost some mid-high there.
https://www.sau.com.au/forums/topic/194796-dyno-graphs/#findComment-3491444
john (my dyno guy) didnt say anything to me at the time (with the first graph), but i mean nothing had been done to the car, hdnt even been serviced yet, as it was only 3 weeks after i got her that she had her first dyno run.
https://www.sau.com.au/forums/topic/194796-dyno-graphs/#findComment-3491573
fair enough, he should have mentioned it to you that your fuel mixtures weren't so crash hot.
you can hardly claim a 16kW gain on the exhaust alone if that is the case. i'd think that there'd roughly be 5-10kW on cleaning up the AFRs alone.
how the hell do ya dyno a auto ya put your foot down and it changes down a gear! lol
dyno runs are normally done in 4th gear, that's the closest 1:1 gear ratio available.
i'm not 100% sure on a slush box, i think (don't quote me) you do the run in 'overdrive'.
http://www.turbomagazine.com/tech/0304tur_...hart/index.html
have a read of that, the last paragraph in particular has quite a bit of emphasis on our topic.
always, always, always request AFRs as the second axis, power is nothing if your car is running like shit. AFRs should always be as close to a flat line as possible. as you can see in your first graph, it runs very very rich towards the late rpm. remember lean = more power, but too lean = boom. tune's normally do have a tendency to run a little rich in high rpm partly as safety.
if you have a look at this sample graph below (random one from the net), you can see the dip in power as the mixture goes rich, and as it leans up again power comes back on. some food for thought.
https://www.sau.com.au/forums/topic/194796-dyno-graphs/#findComment-3491879
yes John did mention that she was running a bit rich with the first dyno graph but once the exhaust was put on it sorted itself out and was a normal a/f mixture after that (despitwe going rich every now and then)
i hope to be getting a power fc soon, so that will be good to see what difference that makes.
https://www.sau.com.au/forums/topic/194796-dyno-graphs/#findComment-3491967
i'm sorry, but i'm not following. one instance you said that he didn't tell you then you say he did tell you.
it wouldn't have been the exhaust that fixed it, you would have either gotten it serviced and it cleaned itself up, a new o2 sensor, started using higher octane fuel or reset your ecu. regardless the power increase isn't from the exhaust alone.
power fc would be good if you can find one, for a cheap price and one suited.
then it's a matter of making it work, which may possibly involve rewiring the loom or changing sensors over on a GTT PFC, as they dont make one for the rb25de (neo included). at the end of the day you're looking at $1.4-1.5 for a powerfc with hand controller and another $3-400 for a tune. that's close to $2k for ~10kW. hardly worth it in my opinion.
how do you know it's going rich every now and then? you TT fuel ratio monitor would hardly be accurate without a wideband O2 sensor, please don't use that to base your judgment on things.
https://www.sau.com.au/forums/topic/194796-dyno-graphs/#findComment-3492175
john told me when i took the car back the second time , when the exhaust had been put on.
a power fc is always going to be better than a piggy back ecu. john had told me from day one that if i am going to get an aftermarket ecu, to get a power fc. there is one is NZL for sale at the moment for $1250, or about $1077 australian dollars, and to fit and tune is out 500.
https://www.sau.com.au/forums/topic/194796-dyno-graphs/#findComment-3493283
I beleive a Power FC is an option if you NEED a stand alone ECU.
Where you dont have an AFM, need continuous tuning, changing A/F ratios, spark, etc. etc.
I think for $1500 your better off getting a set of cams + tune on your current piggy back..
It will yeild far more power than what you will be able to extract from a PFC
Or I dunno.. how many more mods will you be doing?
Cams?
Valves?
Port?
Polish?
C/R?
If so.. instead of getting a re-tune after every mod.. or taking the car off the rd for 3 weeks.. then you may want to buy a PFC now. Save you money in the long run..
Edited by GTS4WD
https://www.sau.com.au/forums/topic/194796-dyno-graphs/#findComment-3493336
BO! (as above)
Save the money Cara..
The extra money.. which is ALOT of money.. is by FAR better spend on cams/port/poslish/CR/Fuel pump/injectors..
Thats where real power is made by NA's.. Focus on the flow and volume of air entering/exiting the engine..
ECU tunes only enhance and extract the all the power that can be unlocked by your modifications.. If you have alot of mods.. the potential that can be unlocked can be quite large..
Spend the money on a piggy back.. and the difference spend on mods.. That way when you do get a complete stand alone ECU system there is a large potential of power that can be unlocked..
I hope this post dosnt come off mean or beligerent.. its been a few drinks now.. I just want to help :D
Its my half drunken 2 cents..
https://www.sau.com.au/forums/topic/194796-dyno-graphs/#findComment-3493793
Also i'd like to make a note that Power Fc's do not work on auto's so they're pretty much out of the picture. i think a few of the others can run autos but cant remember exactuly which ones, i have also read somewhere that it is possible to run a power fc and piggyback the stock ecu to run the auto shifting, i think you have to splice in the sensor wires and wire in the solinoid wires.
I would suggest your best option would be something like the greddy emanage blue piggy back or a motec 600 piggy backed, or as Eug said a SAFC & SITC but the sitc's are discontiuned and can be had to find.
https://www.sau.com.au/forums/topic/194796-dyno-graphs/#findComment-3493820
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
    • This thing did a 1:20.88 at Winton on the weekend which is f**king rapid.  Well done mate, your driving has really gone up a few notches not much left on the table now! Good luck at WTAC.   https://www.facebook.com/share/r/1MHyZQBqZ2/
    • Are you guys meeting up with the Sydney SAU guys at Lambton Pool Carpark or heading straight in?
