ive just purchased some REAR r33 gtr brembos for a very good price....just want to know what is requried to fit r33 gtr REAR brembos to a r32 gtr, i know the rotors are different size, more along the lines of bolt and brake hose differneces or do they just bolt up nice and happy to the standard 32 gtr rotor.
cheers... :(:D
https://www.sau.com.au/forums/topic/194969-fitting-rear-brembos/
cheers... :(:D
When i did my converstion, everything just bolted straight on. I did need to slightly bend out the protective metal which goes around the rotor.
When I fitted 33 GTR Brembo's onto the 32 GTR
I needed:
longer brake line hose approx. 30mm, went to Pirtek to get them made up
300 mm rotors
caliper mounting bolts are a different thread, any bolt place will have them. Make sure that they are Hi Tensile steel (8.8)
brake line and brackets are the same.
Hope that helps
PS. I changed the brake seals aswell for peace of mind.
yes i did :D but you had a bracket and steel lines to fit your larger rotor, while i was doing yours i never checked to see if the brembo just fits with minimal fuss. Just didnt have the time a work, its organized madness. how is your beast sounds like you need to try some changes with setup...
Markk- so the 300 by 22 rotor and brembo caliper fitted up with the same bolts from the 32 with all the steel hoses also from the 32...
I needed:
300 mm rotors
Hope that helps
nice one thanks for the info, just unsure of the size and pitch of the bolt. is it 8.8mm by what pitch.
8.8 is a Hi Tensile bolt rating. The thing is to take the caliper to the bolt place and they will find the correct bolt for the caliper.
yes i did :rofl: but you had a bracket and steel lines to fit your larger rotor, while i was doing yours i never checked to see if the brembo just fits with minimal fuss. Just didnt have the time a work, its organized madness. how is your beast sounds like you need to try some changes with setup...
Everything bolted right up...
But having said that, I am assuming (and could very well be wrong) that 32 gtr Vspec brembos are the same as 33 gtr brembos.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
