  • Replies 56
Posted Images
did u buy this from some guy down south back in may? he wanted low to mid 20's now 6 months later you want 32k? how does that make sence only thing that seems to be changed is the turbo set up?
mate ur obviously trying to cause trouble or something... if u only knew the way it was wen i bought it... and now how much money ive spent on it... i ve spent over well over 10k in the time of me owning it, every single aspect of the motor has been replaced with high quality high performance products coz when i bought it everything was standard except the 'gcg' brand 35/40 turbo!!! on top of that the car interior was not finished to the slightest, the old owner will tell u himself!
Thanks alot for saying that crap in my thread and without being descent enough to pm me to find out the info
Edited by kardieb
I wasnt talking sh*t I was just stating an obvious fact that im sure someone else would have asked if I didnt, now that you have told us what has been done since you have owned it im sure now people can justify why you are asking so much, wasnt trying to wreck your thred dude. GL
oh mate had dramas i had to get my inlet plenum modified coz the 180 bay is so small, i had to delay this tune il get it done wen the new intake side is back on
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
